Having some problems lol
Go to solution Solved by defunkt,
Use the green port. :)
I originally used the optical out on the asus motherboard, but now I want to use front speaker out jack. . . i've switched the default over in the playack menu to speakers from optical out, and when sound plays u can see the eq bar moving, but no sound is coming through speakers. . . I've plugged ipod into speakers and it works with that, but the jack to jack lead from speakers to Motherboard is producing nothing?
CPU: Ryzen 5 3600 | Cooler: Stock | RAM: 16GB Hyper Fury X RGB | GPU: RTX 2080 Super FTW3 | Motherboard: Gigabyte Aorus Elite| PSU: Corsair RM850x
Storage: WD SN750 500GB / 850 500GB Samsung Evo /  | CASE: 570X | Display: Dell u2414h  | KEYBOARD: Corsair K70 | MOUSE: Corsair M65
https://linustechtips.com/topic/67118-having-some-problems-lol/
ASUS_Maximus_V_Gene-16.jpgerm on that it would be bottom left (in case top left)
creative t 20s
https://linustechtips.com/topic/67118-having-some-problems-lol/#findComment-918050
oh bollocks. haha it works. . . so thick i am. #solved thanks
https://linustechtips.com/topic/67118-having-some-problems-lol/#findComment-918058
Should I get a soundcard?
https://linustechtips.com/topic/67118-having-some-problems-lol/#findComment-918110
Do you want a soundcard?
I'm not really sure, that sound is decent tbf, I'll probably decide christmas time, was just sort of wondering how much more benefit it would be, I don't use my comp for listening to music see. If I'm on my comp it's usually just YT, gaming or something like that.
https://linustechtips.com/topic/67118-having-some-problems-lol/#findComment-918343
Well, if you do decide you want something in the future, just get a cheap DAC like the Behringer UCA 202 if you're only using speakers. I doubt you'll notice a huge change in sound quality.
https://linustechtips.com/topic/67118-having-some-problems-lol/#findComment-918395
I hate Begringer, very poor products, might look at some sort of DAC as you say. :)
https://linustechtips.com/topic/67118-having-some-problems-lol/#findComment-918793
FiiO's D3 is another cheap option but it's optical input and USB powered. Behringer's products are hit and miss, the UCA series is good as long as you're no expecting anything great from the headphone port.
https://linustechtips.com/topic/67118-having-some-problems-lol/#findComment-918947
