Will it work?
Go to solution Solved by Oshino Shinobu,
Yes, they will.
Yeah that will work, just make sure your psu isn't junk :P
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/670867-will-it-work/#findComment-8648994
1 hour ago, KahK said:
Hi everyone, I originally bought an  Asus H81M-PLUS Motherboard. I am planning on buying sapphire 11260-02-20G AMD RX 480 Nitro+. Does anyone know that these two will work?
I suggest getting a similarly priced MoBo with Crossfire support. The 480 scales really well, it might be a good idea to get a little futureproofness futurereadyness to you PC.
https://linustechtips.com/topic/670867-will-it-work/#findComment-8649150
