Hello all!
I am currently looking into purchasing a new computer and have been looking into some parts for it, based off of some of the build guides on pcpartpicker.com and mixing them up to fit what I want. Just wondering if anyone of you could check out this list that I came up with and let me know if there is anything that I could change to shave a little $ off or if anything should be changed at all. Thanks guys.
P.S. I already have a ssd on my current computer so I will be moving that to my new build as well as my soundcard
http://pcpartpicker.com/list/6GTyWX
Thanks,
- Andrew
https://linustechtips.com/topic/670129-new-build-help/
4 minutes ago, AgunneR said:
Hello all!
Thanks,
- Andrew
Solid parts, the only thing I might change is to add a SSD to your build. I'd recommend a 256GB Samsung 850 EVO.
http://pcpartpicker.com/product/3kL7YJ/samsung-internal-hard-drive-mz75e250bam
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/670129-new-build-help/#findComment-8641067
http://pcpartpicker.com/list/nTyC8K there. cheaper cpu, you can go down to a cheaper mob if you want also got a cheaper but better hard drive.
Good luck, Have fun, Build PC, and have a Wii and PS2 as your only consoles.
NightHawk 3.0: R7 5700x @, B550A vision D, H105, 2x32gb Oloy 3600, Asrock RX9070xt Steel Legends, Corsair RM750X, 500gb 850 evo, 2tb rocket and 5tb Toshiba x300, 3x 6TB WD Black W10 all in a Obsidian 750D airflow.
GF PC: (NightHawk 2.0): R7 2700x, B450m vision D, 4x8gb Geli 2933, Sapphire RX 6700XT  Nitro+, CX650M RGB, Obsidian 350D
Skunkworks: R5 3500U, 16gb, 500gb 860 evo, Vega 8. HP probook G455R G6 Ubuntu 20. LTS
Condor (MC server): 6600K, z170m plus, 16gb corsair vengeance LPX, samsung 750 evo, EVGA BR 450.
Spirt  (NAS) ASUS Z9PR-D12, 2x E5 2620V2, 8x4gb, 24 3tb HDD. F80 800gb cache, trueNAS, 2x12disk raid Z3 stripped
HP probook 445R G6 review
"Stupidity is like trying to find a limit of a constant. You are never truly smart in something, just less stupid."
Camera Gear: X-S10, 16-80 F4, 35mm F1.4, Helios 44
https://linustechtips.com/topic/670129-new-build-help/#findComment-8641068
That CPU does not allow for overclocking. The 6700k was a solid choice.
Solitaire.
https://linustechtips.com/topic/670129-new-build-help/#findComment-8641072
he asked how to cut costs.
https://linustechtips.com/topic/670129-new-build-help/#findComment-8641076
Like I said, I am moving over my ssd from my current build to the new one. Thanks!
https://linustechtips.com/topic/670129-new-build-help/#findComment-8641083
8 minutes ago, AgunneR said:
Hello all!
Thanks,
- Andrew
To cut costs, you can get a slightly cheaper PSU and mobo:
http://pcpartpicker.com/list/2YjFZ8
EDIT: http://pcpartpicker.com/list/HZYjnn
Solitaire.
https://linustechtips.com/topic/670129-new-build-help/#findComment-8641088
My bad, didn't catch that.
Solitaire.
https://linustechtips.com/topic/670129-new-build-help/#findComment-8641090
