use pcpartpicker and it will tell you if they are compatible
Future Upgrades
VVVVVVVVVVVVV
1: SSD
2: Freesync monitor
3: AIO cooler
4: New HDD
5: RAM upgrade, i want 16gb of black ram
order 1-5 is what I want the most,
color is of importance (most to least)
https://linustechtips.com/topic/669665-pc-help/#findComment-8636621
1 minute ago, PCNoobie said:
YOU NEED Z170 MOBO your i5 6600k. You can't overclock your cpu on mobo that is not Z170.
You don't need one. You would want one, but it's not a necessity.
Also, PCPartpicker says "The BitFenix Prodigy (Blue) Mini ITX Tower Case supports video cards up to 317mm long, but video cards over 177mm may block drive bays. Since the MSI GeForce GTX 1060 6GB 6GB GAMING X Video Card is 277mm long, some drive bays may not be usable."
So essentially your 3.5 inch HDD might not be able to be in its caddy.
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
https://linustechtips.com/topic/669665-pc-help/#findComment-8636665
12 minutes ago, coolmrschill said:
So I'm building my first PC with a mini itx form factor. I orgininally wanted a Cosair 380t but can't find on in stock any where. So going to use the bitfenix prodigy. These are my parts are they all compatible? Thanks Connor
looks good, but I'd change a few things:
1. Blue case with red RAM and GPU...?
2. I'd get a 240GB Sandisk over that SSD
3. as @PCNoobiestated, if you want to overclock, you need a Z170 motherboard, if not, get the i5 6500 instead to save some money.
4. I'd recommend the Cryorig C7 or Hyper 212 EVO over that CPU cooler, but it's not that big a deal.
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/669665-pc-help/#findComment-8636671
I can confirim that you do need a Z170 chipset to overclock. with older operating systems and BIOSs, it has been possible in the past, but no longer.
Solitaire.
https://linustechtips.com/topic/669665-pc-help/#findComment-8636676
https://gyazo.com/c2567b07870553a92111223d6e48112e  would the drives fit in the bottom ones?
https://linustechtips.com/topic/669665-pc-help/#findComment-8636683
yes.
Solitaire.
https://linustechtips.com/topic/669665-pc-help/#findComment-8636700
I've taken a look at the photo, and to me they look like 2.5in drive bays. But if they're 3.5in, you would definitely be able to fit them there. I just can't really tell (I've only worked with dell computers for the past year or so)
https://linustechtips.com/topic/669665-pc-help/#findComment-8636701
Just now, PCNoobie said:
1. He wants mini ITX
2. you do not have a case in that list.
Solitaire.
https://linustechtips.com/topic/669665-pc-help/#findComment-8636704
http://ca.pcpartpicker.com/list/MLhpKZ
My recommendation
Solitaire.
https://linustechtips.com/topic/669665-pc-help/#findComment-8636724
Change the cooler to a Cryorig H7. The rest is great
3 minutes ago, dexxterlab97 said:
PSU from CX to RMX
Mobo more red if you want red build.
Its a white label CX thats a good one
He who asks is stupid for 5 minutes. He who does not ask, remains stupid. -Chinese proverb.
Those who know much are aware that they know little. - Slick roasting me
AXIOM
CPU- Intel i5-6500 GPU- EVGA 1060 6GB Motherboard- Gigabyte GA-H170-D3H RAM- 8GB HyperX DDR4-2133 PSU- EVGA GQ 650w HDD- OEM 750GB Seagate Case- NZXT S340 Mouse- Logitech Gaming g402 Keyboard-  Azio MGK1 Headset- HyperX Cloud Core
Offical first poster LTT V2.0
https://linustechtips.com/topic/669665-pc-help/#findComment-8637545
http://www.newegg.com/Product/Product.aspx?Item=N82E16813132641&cm_re=asus_mini_itx-_-13-132-641-_-Product
-----> Official Unofficial Favorite Keyswitch Type Survey <-----
 OWNER OF THE FASTEST INTEL iGPU ON LTT UNIGINE SUPERPOSITION [lol]
GAMING RIG "SNOWBLIND"
CPU i5-13600k | COOLING Corsair H150i Elite Capellix 360mm (White) | MOTHERBOARD Gigabyte Z690 Aero G DDR4 | GPU Gigabyte RTX 3070 Vision OC (White) | RAM  16GB Corsair Vengeance Pro RGB (White)SSD Samsung 980 Pro 1TB | PSU ASUS STRIX 850W (White)CASE  Phanteks G360a (White) | HEADPHONES  Beyerdynamic DT990 Pro | KEYBOARD Zoom75 (KTT Strawberry w/ GMK British Racing Green keycaps) | MOUSE  Cooler Master MM711 (White) MONITOR HP X32 1440p 165hz IPS
WORK RIG "OVERPRICED BRICK"
Mac Studio (M2 Ultra / 128GB / 1TB) | HEADPHONES  AirPods Pro 2 | KEYBOARD Logitech MX Mechanical Mini | MOUSE  Logitech MX Master 3S MONITOR 2x Dell 4K 32"
SECONDARY RIG "ALCATRAZ"
CPU i7-4770K OC @ 4.3GHz | COOLING Cryorig M9i (review| MOTHERBOARD ASUS Z87-PROGPU Gigabyte 1650 Super Windforce OC | RAM  16GB Crucial Ballistix Sport DDR3 1600 MHzSSD Samsung 860 Evo 512GB | HDD Toshiba 3TB 7200RPMPSU EVGA SuperNOVA NEX 750WCASE  NZXT H230 | HEADPHONES  Sony WH-1000XM3  | KEYBOARD Corsair STRAFE - Cherry MX Brown | MOUSE  Logitech G602 MONITOR LG 34UM58-P 34" Ultrawide
HOLA NIGHT THEMERS
GET YOUR ASS ON NIGHT THEME
OTHER TECH I OWN:
MacBook Pro 16" [M1 Pro/32GB/1TB] | 2022 Volkswagen GTI | iPhone 14 Pro | Sony a6000 | Apple Watch Series 8 45mm | 2018 MBP 15" | Lenovo Flex 3 [i7-5500U, HD5500 (fastest on the forum), 8GB RAM, 256GB Samsung 840 Evo] | PS5, Xbox One & Nintendo Switch [Home Theater setup] | DJI Phantom 3 Standard | AirPods 2 | Jaybird Freedom (two pairs) & X2 [long story, PM if you want to know why I have 3 pairs of Jaybirds]
https://linustechtips.com/topic/669665-pc-help/#findComment-8637565
Just now, dexxterlab97 said:
Colorblind. Sorry. Thought it was just black because of the 800x600 resolution on my laptop
No i meant that as a recommended replacement for his current mobo as the Maximus ITX is expensive AF.
His original pick IS only black lol
HOLA NIGHT THEMERS
OTHER TECH I OWN:
https://linustechtips.com/topic/669665-pc-help/#findComment-8637576
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813132641&cm_re=ASUS_Z170I-_-13-132-641-_-Product
You forgot about CAD
https://linustechtips.com/topic/669665-pc-help/#findComment-8637583
