Phanteks Enthoo Pro M Versus P400 Eclipse
Solved by Trav_X,
Definitely Enthoo Pro M. I wouldn't suggest the P400 unless you are getting the P400S, which would mean you would want a quiet system. But since this is jsut P400, then Enthoo wins by far.
