you could always just use a splitter fitting on the lowest part of your loop. that way you can put in a drain valve which could drain the entire system efficiently.
https://linustechtips.com/topic/669076-drain-valves/#findComment-8630749
8 minutes ago, Nrx said:
Would this be attached to the pump?
it could, but it doesn't need to. it is best to have the drain valve as low as possible though.
https://linustechtips.com/topic/669076-drain-valves/#findComment-8630797
What else could I connect it to?
Well you just need an inline splitter so you could continue your loop and also attach a drain valve as well. Gneerally speaking the pump is one of the more convenient places, but as has been said, it needs to be the lowest point of your loop unless you like manhandling your case to rotate it every which way to get the liquid out.
duc sequere aut de via decede
CPU: i7 6800K | Mobo: MSI X99 Gaming Pro Carbon | GPU: SLI EVGA 980 Ti Hydro Copper | PSU: EVGA 1000P2 | Memory: 64 DDR4 Corsair Dominator Platinum | Storage: Samsung 950 Pro 512GB M.2 & Samsung 850 Evo 1TB| Case: Be Quiet! Dark Base Pro 900 | Display: Predator X34 & Dell U2715H | Cooling: Custom Loop
Custom hard line watercooled Fractal Node 202 ITX build log
https://linustechtips.com/topic/669076-drain-valves/#findComment-8630893
