Hello!
my friend wants a mini wireless keyboard for his tv in the livingroom as a remote to his computer. he has a stationary computer in his room that is connect to the tv by an optic cable which goes under the floor(he did this thing 7 years ago while renovating the house).
the problem is if i connect the wireless keyboard to the computer with bluetooth or 2.4Ghz dongle it wont work... the computer is too far away from the tv. it will be nice to connect with wifi but i didn't find such devices. and he want a physical keyboard. what can we do?
https://linustechtips.com/topic/668982-remote-keyboard-for-tv/
10 minutes ago, jenia1 said:
Hello!
afaik, there isnt a keyboard that works by wifi... it's all bluetooth.
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/668982-remote-keyboard-for-tv/#findComment-8629671
