Looking for replacement HD600 cable
So my HD600 headphone stock cord finally broke. I'm looking for a replacement cable on Amazon. As far as I can tell, I see these:
Third party cable with metal ends (What I'm leaning towards):
https://www.amazon.com/3-9ft-Replacement-upgrade-Sennheiser-headphone/dp/B00X31SNHA/ref=sr_1_1?ie=UTF8&qid=1475219686&sr=8-1&keywords=hd600%2Bcable&th=1
A stock cable:
https://www.amazon.com/Replacement-Cable-SENNHEISER-Headphones-HD650/dp/B0028PGXRE/ref=pd_sim_267_2?ie=UTF8&pd_rd_i=B0028PGXRE&pd_rd_r=6A5EEGDBMF5RQFEBAMBT&pd_rd_w=BN5Sw&pd_rd_wg=upDKR&psc=1&refRID=6A5EEGDBMF5RQFEBAMBT
And a fancier cable with braided silver wire:
https://www.amazon.com/dp/B00JC1R42K?psc=1
Is the fancy cable with the silver wire actually worth it? I just want something that sounds the same / has a higher build quality than the original HD600 cables.
https://linustechtips.com/topic/668934-looking-for-replacement-hd600-cable/
