Upgrading to a 2K monitor for Games Tech (and Gaming)
Solved by ShadowCaptain,
Just now, Xlar Kenziv said:Yeah I mean 1440p, sorry
I thought so, its ok just 2k is a term for cinema DCI 2k which is more like 1080p than it is 1440p which is like 2.6k/2.7k
2k = 2048x
1440p = 2560x
ANYWAY
If you can afford it and want it to last you a long time, look for:
IPS
144hz
Gsync
Brand doesn't matter to much, just check on reviews like tft central if you want an in depth analysis of the screen and check amazon reviews to check their quality control
