Feels like the potential of this build is wasted since you're only playing on a 1080p 60Hz monitor. I would at least try to aim for a 1080p 144Hz or 1440p 60Hz monitor.
I would also get a less overkill power supply on top of that.
'Fanboyism is stupid' - someone on this forum.
Be nice to each other boys and girls. And don't cheap out on a power supply.
CPU: Intel Core i7 4790K - 4.5 GHz | Motherboard: ASUS MAXIMUS VII HERO | RAM: 32GB Corsair Vengeance Pro DDR3 | SSD: Samsung 850 EVO - 500GB | GPU: MSI GTX 980 Ti Gaming 6GB | PSU: EVGA SuperNOVA 650 G2 | Case: NZXT Phantom 530 | Cooling: CRYORIG R1 Ultimate | Monitor: ASUS ROG Swift PG279Q | Peripherals: Corsair Vengeance K70 and Razer DeathAdder
you could change the SSD to a samsung 950 PRO M.2 drive, saves space and is 5x faster than SSD (and fills up the M.2 port on the board)
http://au.pcpartpicker.com/product/FdDzK8/samsung-internal-hard-drive-mzv5p256bw
Also 480 gb on a OS drive is kinda overkill if your using a secondary storage,
I have alot of prgrams installed 85 and i have the anniversary update.
Looks very good! However if you want a white build (which i LOVE), you should really change the RAM. I don't think the graphics card will bother you. IMO the SSD is really large, i'd opt for a smaller cheaper one or a M.2 SSD. Also, if you plan on heavy overclocks the motherboard hasn't got the best quality, but if you won't bother overclocking to the limit, i think you're ok.
