hey i just built my first computer and i'm having some of the worst  frame drops. I'm trying to play SMITE and i'm getting similar frame rates as my old toshiba laptop which is quite disappointing. I would highly appreciate any tips and i will ex plain my whole build.
CPU: FX-6350
MOBO: ASUS M5A99FX PRO R2,0
RAM: Corsair Vengeance 2 x 8GB
GPU: ASUS gtx 1060 3gb
PSU: Thermaltake TR2 600W
MEMORY: 1TB of WD blue
CASE: NZXT Phantom 240
https://linustechtips.com/topic/667857-need-help/
1 minute ago, PCNoobie said:
what is your budget?
Sounds like the computers already built lol
https://linustechtips.com/topic/667857-need-help/#findComment-8617447
5 minutes ago, xStanBerzerk said:
i just went on to the site and downloaded the latest one, should it work from there?
Extract the Zip file and stick the .CAP file BIOS update on a USB flashdrive and use the ASUS EZ Flash 2 Utility from within the BIOS.
C64, MOS 6510 0.985MHz, 64kB RAM + 20kB ROM, 320x200 resolution, 16 colours! <----BEAT THAT! ;P
https://linustechtips.com/topic/667857-need-help/#findComment-8617524
i have done that and have tried to run smite. It had been slightly better but still rather hetrocious
https://linustechtips.com/topic/667857-need-help/#findComment-8617608
U could always try unparking your CPU cores....might give u an FPS boost.
https://youtu.be/Muj_BDJaWf8
https://linustechtips.com/topic/667857-need-help/#findComment-8617665
CPU: FX-6350
Go into your bios and disable TurboCore and APM.
https://linustechtips.com/topic/667857-need-help/#findComment-8617736
