1 minute ago, CloudCommander_ said:
I currently have a 400c but i was wondering if i could change the dust filter top to a solid panel ?
Time to contact Corsair. I don't think such a thing exists but there's always modding companies to do that for you.
https://linustechtips.com/topic/666572-400q-top-panel/#findComment-8604124
its best to contact corsair about that.
i dont think they sell a solid panel for the top....
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/666572-400q-top-panel/#findComment-8604173
