i have a gaming computer and i was seeing if a graphics card would fit in while i was rendering a video late at night. i just had the card hovering over the pcie slot and the IO shield on it touched the motherboard and now it wont turn on. Any help would be nice
Specs: Intel core i5 6500
asus h11om-a motherboard
8bg of DDR4 RAM
1 TB WD blue HDD
EVGA bronze500 WT PSU
https://linustechtips.com/topic/666161-pc-wont-turn-on/
Was there any sparks? Or any damage in the board? Seems like you shorted it
Future Upgrades
VVVVVVVVVVVVV
1: SSD
2: Freesync monitor
3: AIO cooler
4: New HDD
5: RAM upgrade, i want 16gb of black ram
order 1-5 is what I want the most,
color is of importance (most to least)
https://linustechtips.com/topic/666161-pc-wont-turn-on/#findComment-8599910
You attempted to install a GPU while the system was running?  And then you touched it to the motherboard while it was running and the PC blinked out and won't start again.
...Yeah, on that information alone, I think it's pretty possible that you shorted out the motherboard and maybe even did more damage than that.
Also: WHY WOULD YOU DO THAT???
https://linustechtips.com/topic/666161-pc-wont-turn-on/#findComment-8599916
no i did not try to install a gpu while it  was running i was seeing if it would fit
https://linustechtips.com/topic/666161-pc-wont-turn-on/#findComment-8599926
1 minute ago, BuildaMan said:
there were no sparks
Do any capacitors or any parts on the motherboard look budged or broken? Is there anything that has like a brownish color around it.
Future Upgrades
VVVVVVVVVVVVV
1: SSD
2: Freesync monitor
3: AIO cooler
4: New HDD
https://linustechtips.com/topic/666161-pc-wont-turn-on/#findComment-8599936
That in no way makes it any less boneheaded.  It only means that instead of jamming it into the motherboard while it was running, you accidently jammed it into the motherboard while placing it precariously over it.
https://linustechtips.com/topic/666161-pc-wont-turn-on/#findComment-8599939
Yeah, that's not a good idea at all. The system should be off, with no energy in the capacitors at all.
https://linustechtips.com/topic/666161-pc-wont-turn-on/#findComment-8599951
yes i get what i did was stupid and i learned my lesson so if you could not criticize me that would be nice
https://linustechtips.com/topic/666161-pc-wont-turn-on/#findComment-8599953
Just now, BuildaMan said:
none, everything looks as it should. it gets power just it doesn't turn on
Do fans spins and all that? What do you mean by doesn't turn on? Do you just mean there is no video output on the monitor?
Future Upgrades
VVVVVVVVVVVVV
1: SSD
2: Freesync monitor
3: AIO cooler
4: New HDD
https://linustechtips.com/topic/666161-pc-wont-turn-on/#findComment-8599957
with the multi meter it shows power, but nothing turns on, no fans no lights nothing
Yeah seems like you killed your motherboard then
Future Upgrades
VVVVVVVVVVVVV
1: SSD
2: Freesync monitor
3: AIO cooler
4: New HDD
https://linustechtips.com/topic/666161-pc-wont-turn-on/#findComment-8599972
You don't need visible sparks for there to be damage. You might want to check all of your hardware. You could have fried anything that was attached and fried the GPU you were testing for fit....
Lesson learned I guess.
https://linustechtips.com/topic/666161-pc-wont-turn-on/#findComment-8601086
