My current rig is great with games, but I want to edit videos as well. My hardware can barely handle it, so I'm looking at some new parts with better specs on paper. I want to know if it's an upgrade, or not worth it.
Current rig:https://pcpartpicker.com/list/mRjFsJ
Potential Upgrade: http://pcpartpicker.com/list/P82nnn
https://linustechtips.com/topic/665995-hardware-change-help/
that will be a downgrade
in every way
just save up the money and get an i7 6700k
you will thank yourself later
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/665995-hardware-change-help/#findComment-8598295
2 minutes ago, RandommLOL said:
I thought it looked too good to be true.
I'll save up.
Thank you community.
Yeah you'll do way better on getting the i7 6700k.
Also; If you want people to see your replies you should use the quote button, it's the arrow under the comments.
If you want to make sure everything runs smooth with the 6700k I, yet again, recommend a better cooler. You might want to look in to a bigger case that can fit it as well.
https://linustechtips.com/topic/665995-hardware-change-help/#findComment-8598322
