Looking for LED Light
Go to solution Solved by W-L,
2 minutes ago, pdzappa said:
I was wondering if anybody knows of an led similar to the one that comes in the mastercase maker 5 (picture) that is either rgb or comes in different colors than just red. Love the idea of this type of light but would like blue or rgb instead of red.
Thanks for any help!!
Those are just LEDs with an aluminium extrusion and diffuser on top, as of current I don't know of any premade setup for that but you can get RGB LED kits and install them inside of an extrusion with diffuser as such:
http://www.performance-pcs.com/huake-0-5m-super-slim-recessed-aluminum-led-profile-without-flange-using-for-strip-within-12mm-black-frosted-lens.html
https://linustechtips.com/topic/665728-looking-for-led-light/
https://linustechtips.com/topic/665728-looking-for-led-light/#findComment-8596050
There's also corner mount ones that I was thinking of trying in a PC case to see if having the strips on a angle would help light up a motherboard a little more evenly,
https://www.amazon.com/U-Shape-Aluminum-recessed-installation-Mounting/dp/B00M92UUH0?th=1
https://linustechtips.com/topic/665728-looking-for-led-light/#findComment-8596096
This should work nicely. Thanks!
https://linustechtips.com/topic/665728-looking-for-led-light/#findComment-8596100
