Hey, I was looking at ultrawide monitors and noticed that the same size 3440 x 1440p screen costs about 2 times as much as a 2560 x 1080p monitor. How noticeable is the difference between the two? I am looking for one to pair with a GTX 1070.
Don't forget to "Quote" when replying so we can see it.
https://linustechtips.com/topic/665639-ultrawide-resolution-difference/
Better real screen estate when on desktop. The 3440x1440 is a lot better for working or doing stuff.... for games it is about the same except that 2560x1080 is a lot easier on GPU.
Also if you go above 29" 2560x1080 beware of really bad PPI especially if you sit close to your monitor.
So no noticeable difference in games?
Not really. Unless you want larger display then I suggest 3440x1440 34". I have seen 2560x1080 at 35" and it is terrible.
Personaly I am waiting for Samsung CF791.
The resolution is about 1.8 times larger. I personally prefer higher resolution monitors as you can typically fit more on the screen. I use 1440p exclusively now with all of my monitors as it is decently in the middle between 1080p and 4k.
[Out-of-date] Want to learn how to make your own custom Windows 10 image?
Desktop: AMD R9 3900X | ASUS ROG Strix X570-F | Radeon RX 5700 XT | EVGA GTX 1080 SC | 32GB Trident Z Neo 3600MHz | 1TB 970 EVO | 256GB 840 EVO | 960GB Corsair Force LE | EVGA G2 850W | Phanteks P400S
Laptop: Intel M-5Y10c | Intel HD Graphics | 8GB RAM | 250GB Micron SSD | Asus UX305FA
Server 01: Intel Xeon D 1541 | ASRock Rack D1541D4I-2L2T | 32GB Hynix ECC DDR4 | 4x8TB Western Digital HDDs | 32TB Raw 16TB Usable
Server 02: Intel i7 7700K | Gigabye Z170N Gaming5 | 16GB Trident Z 3200MHz
Assuming screens of the same size, the difference is the same as going from 1920x1080 to 2560x1440.
As far as how noticeable the difference is, that depends entirely on the screen size and your particular tolerance for screen sharpness. I have a 21.5" monitor in front of me that runs 1080p in games and i have to turn up the Anti-Ailiasing quite high in order to get rid of unwanted jaggies. that effect will be amplified on a much larger screen. this is where higher resolutions come in handy as they produce finer images in games. Keep in mind that higher resolutions are also more difficult for your GPU to run at high fps.
a 2560x1080p ultrawide in my opinion will look terrible for games.. 1080p is dire.. like i can actually see the individual pixels on a display 26" or larger.. infact i can tell if a monitor is large and 1080p because i get motion sickness almost instantly..
id get a 3440x14400, i have one and can vouch that they are very much worth it! i ahve a 34" acer predator x34.. admittedly they are £900/$1200 but my god was it worth every single penny.
Gaming PC: • AMD Ryzen 7 3900x • 16gb Corsair Vengeance RGB Pro 3200mhz • Founders Edition 2080ti • 2x Crucial 1tb nvme ssd • NZXT H1• Logitech G915TKL • Logitech G Pro • Asus ROG XG32VQ • SteelSeries Arctis Pro Wireless
Laptop: MacBook Pro M1 512gb
If you're referring to a 34"/35" 2560x1080 display, then I can't comment. But, in the case of a 29" monitor, I don't agree with your opinion.....and that's all we're expressing here, opinions. I have an AOC Q2963PM 29" IPS display and it's brilliant for gaming and movies, and no, I don't see the individual pixels. You talk like having a 2560x1080 monitor is crap for gaming, I don't think so.....not everyone is able or willing to pony the cash for a 34" 3440x1440 monitor.
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
