Help me decide!
Go to solution Solved by Inspirational,
I came across this AMAZING case that has a really sleek, rectilinear, and futuristic design!
It also comes with 4 stock fans. Jesus christ.
NZXT NOCTIS 450 - $209 AUD.
I don't know which one of these cases I should get...
I want the best airflow (or space for extra fans that I may purchase in the future).
http://au.pcpartpicker.com/products/compare/3MPfrH,32XfrH,8v38TW,8PPfrH/
If you have any other suggestions, please let me know! I'm after a full or mid ATX tower, that has really good airflow, and can support my build:
http://au.pcpartpicker.com/list/sDV6QV
Thanks~!
This is the current build I am working on:
>>>> The $2500 ($1900 US) Desktop <<<<
>>> Old Build <<<
LAST UPDATED: 30-September-16 / 05:38PM (Sydney Time)
https://linustechtips.com/topic/665405-help-me-decide/
2 minutes ago, Abhinavp said:
Considering your build you should consider cooler master mastercase pro 5. It has GREAT air flow and your build is beast so you need to spend some money for its house?
That's a really nice case!
Would you mind comparing these two for me, and letting me know which one you would suggest? I would like to stick to around $100 AUD.
But I can boost it up if cooler master is significantly better
>>> Old Build <<<
https://linustechtips.com/topic/665405-help-me-decide/#findComment-8592950
>>> Old Build <<<
https://linustechtips.com/topic/665405-help-me-decide/#findComment-8599844
