Not a "battery pack" in the sense of something portable but there are devices called Uninterruptible Power Supplies that Are a big battery built into the surge protector (they are fairly heavy) and if properly sized will give you enough time to exit what you are doing and shut down the computer properly, I need to get one myself, last week I was trying to tweak the case fans in the Bios and the power kept going out on my BRAND NEW SYSTEM, it's REALLY ANNOYING (part of why i've kept to laptop use for most stuff, I also want to get one for work just to run me that 10-15 seconds between a power outage the Emergency Generator kicking on so I won't keep losing hours worth of work.
https://linustechtips.com/topic/665366-battery-pack/#findComment-8592437
You're going to need a uninterruptible power supply, and a good one at that if you want the computer to still survive a power loss while you're gaming (unless you aren't). However, they're mostly to give you enough time to cleanly shut down the computer, so about 30 minutes or so.
https://linustechtips.com/topic/665366-battery-pack/#findComment-8592446
3 hours ago, RexTheCapt said:
Any recommedations? My powersuply is 550 W and the monitor i want to be alive is an AOC e2752Vq.
I've had 2 of these: http://www.newegg.ca/Product/Product.aspx?Item=9SIA7RD2WW8809 for 3 years and have worked flawless.1 powers my monitors and Modem,the other powers the PC.
550 wat psu means nothing.Thats just what your PSU is rated at.
ASUS Crosshair VIII Dark Hero X570**AMD Ryzen 5800X**16G Corsair Vengence RGB 3600Mhz **ASUS Strix RX6700XT OC**Corsair H150i RGB Platinum AIO**Samsung 2-2TB 970 EVO Plus m.2**2-860 2 1/2 EVO 1Tb SSD's**Creative Sound Blaster Z**Corsair HX1200i PSU w/Black sleeved corsair Cables**Corsair 5000D Airflow**BenQ XL2730Z 1440p 144Hz 27"**BenQ XL2720Z 27"**Corsair K95 RGB Platinum Keyboard**Roccat Kave 5.1 Gaming headset,Roccat Kone Pure Black Gaming mouse**Windows 10 PRO
_____________________________________________________________________________________________________
https://linustechtips.com/topic/665366-battery-pack/#findComment-8594396
Honestly start by getting a Kill-a-watt power meter and see what kind of wattage you are actually pulling from the wall to run everything and go from there using the video above, or go all out and buy the biggest unit you can get, just make sure it's at least big enough to handle your system at load.
https://linustechtips.com/topic/665366-battery-pack/#findComment-8596875
i get 230 watt from the wall
https://linustechtips.com/topic/665366-battery-pack/#findComment-8605339
9 hours ago, W-L said:
What components are in your system we can get a better idea of what your needs will be.
My power supply for my computer is on 550 watt, My monitor is an AOC e2752Vq (i don't know how much watt my monitor use), and the AC power outles supplies 230 watt.
My computer specs are:
  • Motherboard: Maximus Hero VII
  • CPU Intel Core i5 4690K
  • RAM: Kingston KHX1600C10D3/8G
  • Graphics:
    • Intel(R) HD Graphics 4600
    • AMD Radeon R9 200 Series (Primary)
More detailed info: http://pastebin.com/wyYL7v45
https://linustechtips.com/topic/665366-battery-pack/#findComment-8619711
  • Graphics:
What's the GPU exact 200 series is very generic as it can vary wildly to what you will need.
Just basing at around the ~230W and a little more something like this would be a good option:
http://www.apc.com/shop/ca/en/products/APC-Power-Saving-Back-UPS-750VA-10-outlet-120V-Canada/P-BE750G-CN
https://linustechtips.com/topic/665366-battery-pack/#findComment-8621334
I can't use that one. The AC outlet we are using is this one
https://linustechtips.com/topic/665366-battery-pack/#findComment-8621653
Ah ok those would be schuko plugs so you will need something like this instead, a 405W capable unit would be more than what you would need basing it off the approx 200W power draw:
http://www.apc.com/shop/no/en/products/APC-Power-Saving-Back-UPS-ES-8-Outlet-700VA-230V-CEE-7-7/P-BE700G-GR
https://linustechtips.com/topic/665366-battery-pack/#findComment-8622263
