Help: Access Point / Switch
Go to solution Solved by Jarsky,
32 minutes ago, Junior Tan said:
Oh just realized that it was a bridge, thanks for pointing that out.
i also saw http://www.dlink.com.sg/product/dap-1665-ac1200-wireless-access-point/#nf_overview what do you think?
That doesnt have a built in switch, it has a single port for connecting to your primary router.
This would work though, but you would need to do as i stated above.
http://www.dlink.com.sg/product/ac1200-wireless-dualband-gigabit-router/
So if we take your main internet router as Router 1, and the one in your bedroom as Router 2.
Router 2 - disable DHCP
Router 2 - Assign a static IP in the same class as Router 1. (i.e if Router 1 is 192.168.1.1 then Router 2 is 192.168.1.2. Another way you can do it, is get the mac address of router 2, and in router 1 you reserve 192.168.1.2 to router 2's mac address if router 1 has this feature)
Router 1 - Assign Router 2's IP address to the DMZ
Router 2 - Enable Wifi and configure the same SSID & Password that you use for Router 1 (so when you move around the house, it moves between AP's)
Or you can get a Switch + Access Point only.
The main reason I recommended that Mikrotik RB260GSP is because it is compact, and has PoE on ports 2 & 5 which means you only have 1 cable going to a PoE compatible AP such as the Ubiquiti UAP-AC-Lite making it more tidy, and taking up less power sockets.
https://www.alagasnetwork.sg/estore/mikrotik/integrated-solutions/switches/mtik-rb260-gsp.html
http://www.lazada.sg/ubiquiti-unifi-dualband-ac1167-access-point-uap-ac-lite-4220897.html
Scenario: Fiber modem-router at living room, new desktop in master bedroom, wants to have it connected via LAN but also need good WiFi signal with same SSID in the room. I have a 15m CAT cable long enough to reach master bedroom from modem.
Question: Is there any AP with multiple ports that can also work as desktop switch.
Any kind of help is appreciated, thanks!
https://linustechtips.com/topic/665030-help-access-point-switch/
Do you need more than two?
[FS][US] Corsair H115i 280mm AIO-AMD $60+shipping
System specs:
Asus Prime X370 Pro - Custom EKWB CPU/GPU 2x360 1x240 soft loop - Ryzen 1700X - Corsair Vengeance RGB 2x16GB - Plextor 512 NVMe + 2TB SU800 - EVGA GTX1080ti - LianLi PC11 Dynamic
https://linustechtips.com/topic/665030-help-access-point-switch/#findComment-8588613
you'd be better off with a second switch.
UniFi AP Pro has two ports.
System specs:
https://linustechtips.com/topic/665030-help-access-point-switch/#findComment-8588629
Unless you have Gigabit fiber, just put the AP with the modem and connect the desktop via wireless AC.
Desktop: Ryzen9 5950X | ASUS ROG Crosshair VIII Hero (Wifi) | EVGA RTX 3080Ti FTW3 | 32GB (2x16GB) Corsair Dominator Platinum RGB Pro 3600Mhz | EKWB EK-AIO 360D-RGB | EKWB EK-Vardar RGB Fans | 1TB Samsung 980 Pro, 4TB Samsung 980 Pro | Corsair 5000D Airflow | Corsair HX850 Platinum PSU | Asus ROG 42" OLED PG42UQ + LG 32" 32GK850G Monitor | Roccat Vulcan TKL Pro Keyboard | Logitech G Pro X Superlight  | MicroLab Solo 7C Speakers | Audio-Technica ATH-M50xBT2 LE Headphones | TC-Helicon GoXLR | Audio-Technica AT2035 | LTT Desk Mat | XBOX-X Controller | Windows 11 Pro
Server: Fractal Design Define R6 | Ryzen 3950x | ASRock X570 Taichi | Asus RTX 4060 Dual OC | 64GB (4x16GB) Corsair Vengeance LPX 3000Mhz | Corsair RM850v2 PSU | Fractal S36 Triple AIO + 4 Additional Venturi 120mm Fans | 8 x 20TB Seagate Exos X22 | 4 x 16TB Seagate Exos X18 | 3 x 2TB Samsung 970 Evo Plus NVMe | LSI 9211-8i HBA
NAS: Innovision 4U 24-bay chassis (12GB MiniHD SGIO Backplane) | Intel Core i9-10980xe | EVGA X299 FTW-K | EVGA RTX 2080Ti Super FTW3 | 128GB (8x16GB) Corsair Vengeance LPX 3200Mhz | DEEPCOOL PN1000M PSU| Noctua NH-D12L Chromax Black | 16 x 16TB Seagate Exos X18 | 2 x 2TB Samsung 990 Pro | 2 x 2TB Intel U.2 P4510 | LSI 9305-24i HBA
https://linustechtips.com/topic/665030-help-access-point-switch/#findComment-8588650
one of two ways.
UniFi AP Pro or a gigabit switch in the room with a UniFi AP connected to it.
UniFi Pro: $150US (much cleaner)
Gigabit switch with UniFi AP: $90US-ish
System specs:
https://linustechtips.com/topic/665030-help-access-point-switch/#findComment-8588659
I do have Gigabit fiber. My fiber modem is actually a modem router hybrid thingy. So there is already wireless in my house, but as usual with this kind of modem routers is that their WiFi are terrible.
https://linustechtips.com/topic/665030-help-access-point-switch/#findComment-8588681
4 minutes ago, knightslugger said:
one of two ways.
So you are saying that i have the switch in the master bedroom connected to the 15meter LAN, and have an AP connected to the switch?
https://linustechtips.com/topic/665030-help-access-point-switch/#findComment-8588691
In that case, i'd look at something like this:
https://www.roc-noc.com/mikrotik/routerboard/260GSP.html
Giving you 4 Gigabit ports + 1 PoE port you could use to power a PoE capable Access Point
https://linustechtips.com/topic/665030-help-access-point-switch/#findComment-8588730
Not sure if that is available in Singapore.
What about something like https://www.asus.com/sg/Networking/EAAC87/overview/ if i can't get my hands on that
https://linustechtips.com/topic/665030-help-access-point-switch/#findComment-8588742
Thats a wireless bridge, its designed for joining 2 wired networks over wireless.
I don't know enough about that device, if you can repurpose one of the 5 ethernet ports to connect to your main router. Theres nothing stopping you using another all-in-one router as a switch & AP though. You just need to set a different IP address to your primary router, disable services on it like DHCP so you dont cause conflicts, and disable the firewall or put it in a DMZ (demilitirized zone) so you dont get double NAT'ing.
https://linustechtips.com/topic/665030-help-access-point-switch/#findComment-8588812
https://linustechtips.com/topic/665030-help-access-point-switch/#findComment-8588869
If you need an AP in the same room as the destop, then yes, that is it exactly.
System specs:
https://linustechtips.com/topic/665030-help-access-point-switch/#findComment-8589000
https://linustechtips.com/topic/665030-help-access-point-switch/#findComment-8589204
Thanks! So basically get a gigabit router and run it as an AP or get the switch + PoE AP. I think i will go for whichever is cheaper for me.
https://linustechtips.com/topic/665030-help-access-point-switch/#findComment-8589248
You got it. Basically by doing those steps, you're disabling the routing features - and turning the router into a layer 2 switch with built in AP.
https://linustechtips.com/topic/665030-help-access-point-switch/#findComment-8589300
