Anyone want to link me a thermal compound? I know fuck all about them.
I was just going to buy this https://www.amazon.co.uk/gp/product/B0045JCFLY/ref=s9_simh_gw_g147_i1_r?ie=UTF8&fpl=fresh&pf_rd_m=A3P5ROKL5A1OLE&pf_rd_s=desktop-1&pf_rd_r=7HBTY4MGHCQ1EGV3XWZ1&pf_rd_t=36701&pf_rd_p=026d359a-cb34-4790-9249-ec9f152ee8e2&pf_rd_i=desktop because it has good reviews etc, and the compound that comes on the h100i v2 that I bought has loads of complaints.
Also, do i just wipe the current compound off with a piece of tissue, would that be okay?
Thanks!
Main Rig
CPU: Ryzen 2700X
Cooler: Corsair H150i PRO RGB 360mm Liquid Cooler
Motherboard: ASUS Crosshair VII Hero
RAM: 16GB (2x8) Trident Z RGB 3200MHZ
SSD: Samsung 960 EVO NVME SSD 1TB, Intel 1TB NVME
Graphics Card: Asus ROG Strix GTX 1080Ti OC
Case: Phanteks Evolv X
Power Supply: Corsair HX1000i Platinum-Rated
Radiator Fans: 3x Corsair ML120
Case Fans: 4x be quiet! Silent Wings 3
https://linustechtips.com/topic/664927-thermal-compound/
Thanks!
I'm currently using the same thermal compound, it's great and pretty cheap. Just a really good value. You can take a look at this webpage to see how it performs against others: http://www.tomshardware.com/reviews/thermal-paste-performance-benchmark,3616-17.html
Using a piece of tissue is totally fine, I would also use a drop or two af alcohol, it's non-conductive and it evaporates almost immediately; it's just to wipe it off more easily.
DESKTOP PC - CPU-Z VALIDi5 4690K @ 4.70 GHz | 47 X 100.2 MHz | ASUS Z97 Pro Gamer | Enermax Liqmax II 240mm | EVGA GTX 1070Ti OC'd
HOME SERVER | HP ProLiant DL380 G7 | 2x Intel Xeon X5650 | 36GB DDR3 RDIMM | 5x 4TB LFF Seagate Constellation 7.2K | Curcial MX500 250GB | Ubuntu Server 20.04
https://linustechtips.com/topic/664927-thermal-compound/#findComment-8587427
the two "go to" thermal compounds on the market today are AS5 (arctic silver 5) and MX-4. either of those would be good in your machine. Linus also likes IC Diamond, but it is not really any better performing than these options and is a bit more expensive.
https://linustechtips.com/topic/664927-thermal-compound/#findComment-8587474
Thanks!
A lot of people use MX-4, some use AS5 like Zyndo said if they want a metallic base. I personally use Noctua's NT-H1; soooo easy to use, consistency is just right and performs really well.
https://linustechtips.com/topic/664927-thermal-compound/#findComment-8587488
Tissue works.
The h100i v2 comes with good preapplied paste. There's no need to replace it.
https://linustechtips.com/topic/664927-thermal-compound/#findComment-8588984
