HeyGuys
So i have my new gaming pc: i5 6500. mb msi h110 vd pro, 16gb ram, r9 380x
On speccy it tells me my motherboard is at constant 111/112 C.  Is that even possible? i have a case with great air fflow and 3 fans(2 intake 1 exhaust). Is it a glitch or should i be worried?
https://linustechtips.com/topic/664808-motherboard-temperature/
4 minutes ago, InsertFunnyNameHere said:
HeyGuys
wouldnt your motherboard be dead if your temps were that high? I would check your ram, cpu, and gpu temps to see if they are that high as well. When i finished my current rig it said my gpu fan was spinning at 433 million rpm but that went away after a few days.
https://linustechtips.com/topic/664808-motherboard-temperature/#findComment-8586307
6 minutes ago, InsertFunnyNameHere said:
HeyGuys
my cpu and gpu are both running at low temps(around 30 idle) i  guess its just a bug thanks
https://linustechtips.com/topic/664808-motherboard-temperature/#findComment-8586312
