22 minutes ago, Master Kusho said:
What's a good adapter for a tower to access wifi
http://pcpartpicker.com/product/G4H323/tp-link-wireless-network-card-tlwdn4800
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/664375-wireless-for-desktop/#findComment-8581365
Just now, Master Kusho said:
Is there any benefit to the 3 antennas or??? Also what makes it better than any other Adapter on the market ?
it is cheap and does the job, and i dont know the benefit but you can point it easyer
Intel Core I5-6500, Gigabyte GTx 750 Ti 4Gb
https://linustechtips.com/topic/664375-wireless-for-desktop/#findComment-8581372
2 minutes ago, BristolBrick said:
Don't know if it's practical, but use Ethernet unless you can't. WiFi emits (arguably) dangerous radiation, is slower, unreliable and has security issues.
And how is wifi emitting dangerous radiation ??? Can you site any source of evidence to back up any of your claims????
https://linustechtips.com/topic/664375-wireless-for-desktop/#findComment-8581431
I said arguably because I'm not sure. Although Wifi works by emitting radio waves (aka radiation) (dunno frequency) and harmful stuff is just a different frequency. (Doesn't mean whatever frequency wifi uses is/isn't though)
https://linustechtips.com/topic/664375-wireless-for-desktop/#findComment-8581461
