AIO Help!
Solved by KamiKatze,
Thats my case I'm pretty sure the H220 will fit in there?
Now to pick some fans, i like the look of the performance on the noctuas but they dont look as good as the corsair, decisions, decisions.....
Yeah don't know if it wil fit. Pretty sure it will. Google it.
Your case doesn't have a window so why not noctuas?
If you're picky like me you may wanna look out for something more eye candy.
as you said, decisions...
good luck
