Not sure if this is the best place to ask for info, or if im even allowed to here :P
im brand new to building a pc, and my experiences so far have been horrible to say the least.
im currently having issues with my pc build, after hours of assembly.
My case is the fractal define nano s, and after turning it on, the Blue LED on the front, flickers, and makes a light cracking sound when it does flicker.
im not sure if anyone else who has made a build with this case has had a similar issue, i looked around a bunch online and some suggest it may be the motherboard, or the PSU.
does anyone reccoment i rejiggle the parts around, or try disconnecting something? or if i should just send the mobo or psu back as faulty.
im extremly new to this and this has been extremly stressful, so far i removed the power LED (i think) and that didnt make a difference, and i made sure the powercables were pushed in tight, so i dont think thats an issue.
https://linustechtips.com/topic/663396-pc-help/
Is it the hdd indicator light that lights up when somehing is writing to your hdd, and the crackling sound may be your hdd.
 •E5-2670 @2.7GHz • Intel DX79SI • EVGA 970 SSC• GSkill Sniper 8Gb ddr3 • Corsair Spec 02 • Corsair RM750 • HyperX 120Gb SSD • Hitachi 2Tb HDD •
https://linustechtips.com/topic/663396-pc-help/#findComment-8571132
well it might be that some Cables going into your motherboard arent in properly
or It could be your HDD light
PC's I Have Built And Currently Still in House:
Main PC (My One):
CPU: Intel Core i7 7700k @5.00Ghz
Motherboard: Asus Strix Z270-E Gaming ATX
Ram: G.Skill Trident Z 32gb (4 x 8) 3200mhz
Storage: 2TB Segate Barracuda HDD, 960gb HyperX Savage (Games), 240gb Samsung 850 Evo (OS)
Case: Corsair 750D
Power Supply: EVGA Supernova 1000w PSU
Graphics Card: 2x Asus Strix GeForce GTX 1080TI (SLI)
Operating System: Windows 10 Pro
Cooling: Custom Water Cooling
https://linustechtips.com/topic/663396-pc-help/#findComment-8571136
Just now, SirBun said:
Hi, i have a 2tb HDD installed. my OS (windows 10) is installed on my HDD yes. is the issue my hard drive then, and how do i fix it if it is? :)
You don't, it is normal for an hdd to make light crackling sounds.
https://linustechtips.com/topic/663396-pc-help/#findComment-8571143
for the commentor above i have the 2tb HDD WD black.
from the comments this sounds normal, it just worried me as a first time builder that i have done something wrong, its not an awful flickering or noise, but it is noticable and made me worry i had done something wrong.
https://linustechtips.com/topic/663396-pc-help/#findComment-8571157
Ill have an ssd arriving soon, will installing windows onto the SDD remove the light crackling noise and the flicking? i feel silly worrying over the last day that my build had gone wrong and id have to return something. trouble shooting for me is basically typing my issue into google and hoping something comes up :P thanks for the quick responses guys, much appreciated.
https://linustechtips.com/topic/663396-pc-help/#findComment-8571224
yes will do, i planned on putting the SSD in anyway, but amazon didnt send me the one i bought, asked for a replacement and they will send it wednesday. i built the system on saturday. first i had issues with connection (turned out to be ram) then i had monitor issues (need to send it back) then i was worried about this, thanks for the help though, set my mind at ease. :)
https://linustechtips.com/topic/663396-pc-help/#findComment-8571383
No it won't remove the noise. The noise is a tiny arm moving back and forth on a tiny spinning disk. Data is stored on this disk so any time you need to load anything from it, it will make this noise. By having the OS on an SSD, you won't be accessing Windows files from the HDD, so it will make that noise less frequently. This noise is totally normal, and the light is designed to flash when data is being read.
I edit my posts a lot.
https://linustechtips.com/topic/663396-pc-help/#findComment-8571626
so its normal for it to make this noise when idle? it isnt a bad noise, and i did notice it flashing and clicking more when i was installing windows onto it :) just worried my HDD is fauly on arrival, when idle it just makes occasional clicks and flashes, is that normal too? sorry for repeated questions. im new to this and just want to make 100% sure. thanks :)
https://linustechtips.com/topic/663396-pc-help/#findComment-8571651
No, if your SSD is large enough, you can potentially put your OS and any games or software on the SSD. I have the same setup and only access my hard drive for music/tv shows/ movies. Therefore I don't hear the disk since I'm at that point listening or watching something! :)
Best of luck to your build. And asking questions is not looked down on, it's how you learn!
https://linustechtips.com/topic/663396-pc-help/#findComment-8572388
yeah thanks for the speedy replies, i unplugged the SATA cable and booted it up, its definetly the HDD, guess i was just so surprised by the noise and flashing, i had already had issues with ram, and connectors, ive had to send my monitor back for bad backlight bleed, and the cpu cooler will probably have to be reinstalled (too much thermal paste i think) to say the least this is a lot more stressful than i had intended. thinking i broke something or something just wont work, is extremly worrying. especially the ordeal i recently had trying to return a monitor. but thanks everyone for the replies, it was only simple but put my mind at ease, and saved me a ton of stress and most likely failed troubleshooting.
https://linustechtips.com/topic/663396-pc-help/#findComment-8573525
