I set my i5 6600k to 4.2 ghz at 1.300v it was running fine but I made the base clock frequency 200 and the multiplier to 22 equalling to 4.4ghz at the same voltage my system's fans are running but it doesn't give a signal now and I have a 212 evo it keeps it cool and there is sufficient power for the system can you help me out
https://linustechtips.com/topic/663111-can-u-help-me/
reset the BIOS
the fsb overclock is unstable from the looks of it
when you OC FSB
you affect the RAM and PCI-E speeds which affect RAM and GPU
Budget? Uses? Currency? Location? Operating System? Peripherals? Monitor? Use PCPartPicker wherever possible.
Quote whom you're replying to, and set option to follow your topics. Or Else we can't see your reply.
https://linustechtips.com/topic/663111-can-u-help-me/#findComment-8568417
