How to mount GPU vertically?
Go to solution Solved by W-L,
Just now, wasiq614 said:
how to i make a cutout in my case :/
The easiest would be to mask off the section and layout your dimensions you need to cut and to use a dremel and a reinforced abrasive cutoff wheel to make the hole. It's good practice to cut away from the lines and to use a metal file to finalize and clean everything up to the line. After you can drill and bolt the PCI-E or rivet it into place.
I have an Asus gtx 1060 GPU and Nzxt H440 case.
Can someone please tell me how I can mount the card vertically in my case?
is there a tutorial or something cause i cant seem to find any :/
I want something like this http://i.imgur.com/LNkleGt.jpg
For something like that you will need to make a cutout for a PCI-E bracket like this to allow for the GPU to be side mounted.
http://www.mountainmods.com/pci-modular-io-bracket-p-701.html
You need a PCIe Flex riser card so you can connect the GPU to the motherboard.
CPU Cooler Tier List  || Motherboard VRMs Tier List || Motherboard Beep & POST Codes || Graphics Card Tier List || PSU Tier List
Main System Specifications:
CPU: AMD Ryzen 9 5950X ||  CPU Cooler: Noctua NH-D15 Air Cooler ||  RAM: Corsair Vengeance LPX 32GB(4x8GB) DDR4-3600 CL18  ||  Mobo: ASUS ROG Crosshair VIII Dark Hero X570  ||  SSD: Samsung 970 EVO 1TB M.2-2280 Boot Drive/Some Games)  ||  HDD: 2X Western Digital Caviar Blue 1TB(Game Drive)  ||  GPU: ASUS TUF Gaming RX 6900XT  ||  PSU: EVGA P2 1600W  ||  Case: Corsair 5000D Airflow  ||  Mouse: Logitech G502 Hero SE RGB  ||  Keyboard: Logitech G513 Carbon RGB with GX Blue Clicky Switches  ||  Mouse Pad: MAINGEAR ASSIST XL ||  Monitor: ASUS TUF Gaming VG34VQL1B 34"
how do i make a cutout in my case :/
is this pretty much the only way of holding the the card in place?
Yes it needs a way to solidly mount into place either with a bracket or something fabricated to do a similar job since that will be the only thing holding it up compared to normally where the PCI-E helps to take part of that strain.
thanks a lot. one last question, the reason I wanna mount my card vertically is because im going with an all white and red build and unfortunately my card doesnt have a back plate that i can paint white or red to go with build. I dont want the ugly pcb of the card to be showing in the case is there anyway i can cover that up? with like a white tape or something? and would it effect the performance of my card? Thanks again
I wouldn't recommend tape it would get all sticky overtime you can get custom made acrylic bakcplates from places like Cold Zero, just to give you some options there are cases like the Deepcool Genome that has the side mounted bracket build in place to hold the GPU in that orientation you are looking for.
http://www.coldzero.eu/
http://www.custompcreview.com/news/deepcool-launches-gamer-storm-genome-pc-chassis-with-integrated-liquid-cooling/27999/
problem is i already bought the case and i have plans on moding this case to go along with my build.
id love to buy a back plate for my card but i looked at coldzero they dont seem to have one for my card :(
Try contacting them directly I know they do custom work, if you want to do it yourself you can also get some acrylic to cut to size and drill mounting holes for it.
