I bought practically a new computer so this may be particularly dificult to solve. I recently acquired a new cpu, gpu, ram and mobo. Intel 6600k, Gtx 1060, corsair vengance lpx ddr4 2400mhz 1x8gb and last but not least a Asus z170-a.
The main problem is that when i finished plugging all the cords and components together, the mobo just wouldnt react either to the case´s power button or the mobo power button for it to turn on. All the changes i can see upon pluggin uin the psu to the power outlet, is that a little light on the mobo called PWR_LED turns green, thats it. The psu works fine in the computer im writing this post with so i can fairly discart the psu as the problem.
I have already tried "breadboarding" it with only the cpu, cooler, 1 stick of ram (in all the posible slots), and a HDD in the "OS Drive" SATA port.
One thing i noticed is that the 6600k supports  DDR4-1866/2133, DDR3L-1333/1600 @ 1.35V  and the memory i have is 2400mhz. The motherboard should support it by downclocking the memory, right?
When i say that the pc does not boot nor post, i actually mean that after all the right components are plugged in, when i press the power button in either the case or the mobo, absolutely nothing happens. No fans, no beeps from the mobo speaker. Nothing.
The difficult part of diagnosing this myself is that all the components are new and most not compatible with my old mobo so i cant test any of them individually. I REALLY hope the mobo is not busted...
THANK YOU ALL IN ADVANCE!
*UPDATE* I sent the build to a technician and the first thing he did was check with another psu to see if that was the peoblem. It wasnt, with neither psu did the pc boor neither post. He will diagnose further and get the results on friday (he currently has no ddr4 rams nor ddr4 mobo's but hes getting them on wednesday, so thats the delay)
Edited by Homero06
Update
https://linustechtips.com/topic/662958-help-pc-does-not-boot-nor-post/
I'm 96% sure it'll be the RAM. Failing that that board is faulty, or the CPU. Have you tried turning it on with a screwdriver and clearing CMOS?
Main Gaming Rig:
Core i7-4770, Cryorig M9i Cooler, ASUS B85M GAMER, 8GB HyperX Fury Red 2x4GB 1866MHz, KFA2 GTX 970 Infin8 Black Edition "4GB", 1TB Seagate SSHD, 256GB Crucial m4 SSD, 60GB Corsair SSD for Kerbal and game servers, Thermaltake Core V21 Case, EVGA SuperNOVA 650W G2.
Secondary PC:
i5-2500k OCed, Raijintek Themis, Intel Z77GA-70K, 8GB HyperX Genesis in grey, GTX 750 Ti, Gamemax Falcon case.
I already tried so many things that i forgot to mention those 2. Yes, cleared the cmos, used another battery, tried the screwdriver trick, even plugged the cpu to the optional slot just in case. No response from the mobo.
What?
Main Gaming Rig:
Secondary PC:
7 minutes ago, Homero06 said:
-snip-
Unplug the Power Switch connector from the board and short the two pins with any piece of metal. A screwdriver works well. Shorting these two pins basically does what that power switch does.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
If you mean jumpstaring the boot with the "scredriver trick" ive already tried that. Nothing happened.
They've tried that.
Main Gaming Rig:
Secondary PC:
Sentey Essential 750w (EPP750)
That may be your issue. It's awful. Replace it.
Main Gaming Rig:
Secondary PC:
But why? I used one of those online watt calculators and the total wattage wasn't over 350.
I'll let @STRMfrmXMN explain better. It's the quality, not the wattage. An awful PSU is likely to just not work, or blow up, killing your components. Most cheap awful PSUs deliver most of their wattage where it's not needed as well.
Main Gaming Rig:
Secondary PC:
What a bummer. I live in argentina and i kid you not, all pc components are DOUBLE the price so ill have to wait till next paycheck to buy a better psu. Regardless of that, are you all CERTAIN the psu is the problem or is just a posible part of the solution? (Ill try to take the pc assembled to a repair center and ask them to try with a psu of their own)
if the fans, gpu, lights etc were on then it could have been RAM but everything is off so i think psu is the culprit here
Ok, ill have into serious consideration to buy a new one. Did you consider the fact that the green led on the mobo was lit? Anyway, which is the cheapest (but of reasonable quality) psu for my rig? Recommendations?
Read This : http://superuser.com/questions/1024656/asus-z170-a-no-post
Corsair is good
Sounds like a firebomb. Sentry has a few good units but I don't believe that's one of them.
It has worked great for me so far, in my previus rig i had gtx 760, some 5 y/o gigabyte mobo, 2 sticks of 4gb hyperx ram, a 3 tb hdd, and a bulldozer cpu. I personally trust it since the psu necer failed me but... If you are all so sure.
