Just now, scubaskot said:
Heya, can someone explain the readings and why TMPIN3 is fluctuating from 30 ° celsius in idle to 39-43 °, sometimes 55 even 60 when im web-browsing? Thanks.
My system:
Asus z170 pro gaming
i7 6700k stock
8 gb ddr4 kingston
Seasonic 620W Bronze.
NO GPU atm.
CHECK your airflow or cpu cooler.
Just now, lolimpol said:
chack any background proccesses in windows, task manager: advanced at the bottom
i checked that too. when the cpu is at 1-2% the TMPIN3 stays between 29-30, when im web-browsing jumps immediately to 39-45 and it goes back to 33-35. but when im refreshing a page then it goes back to high temperatures...
damn, that's pretty weird...
if you are using google chrome try disabling hardware acceleration when available in settings
l i7 5930k | Rampage V Extreme | Corsair H110i GTX | G.Skill Ripjaws 4 16GB DDR4 3000Mhz | EVGA GTX 1070 Superclocked ACX 3.0 | EVGA SuperNova 750w G2 | Samsung 960 Evo 250GB l Samsung 950 Pro 256GB | Samsung 850 EVO 250GB | Samsung 840 EVO 250GB | 1 TB WD Red | Corsair 900D |
Evolution - https://uk.pcpartpicker.com/list/LbJq9W
CPU-Z Validation - http://valid.x86.fr/3dxmew
2 minutes ago, scubaskot said:
Im using firefox most of the time. and here is a test stress -5 minutes, it reached 73 now cause its a bit hot in my room,
Those temperatures don't look concerning to me. If you want to experiment where the heat is I would hold a fan blowing air over the PCH heatsink, to see if that drops that temperature reading. It might be worth looking at your case airflow to make sure it is sufficient.
What is the ambient temperature?
How many hours ago did you apply the arctic silver?
thats just vrm temps on your mobo. the problem is you have an aio so there isnt great airflow to the mobo heatsinks. you could either add some more case fans or if you have a spare fan, have it blow directly over the area around the socket
Altair - Firestrike: http://www.3dmark.com/3dm/13945459
CPU:  i7-4790 @ 3.6 GHz Motherboard: Gigabyte B85M-DS3H-A RAM: 16GB @ 1600MHz CL11 GPU: XFX RX 470 RS Storage: ADATA SP550 240GB | WD Blue 1TB | Toshiba 2TB PSU: EVGA B2 750W Case: Phanteks Enthoo Pro Fans: Phanteks PH-F200SP (Front) | Phanteks PH-F140SP (Rear) | Noctua NF-A15 (Top)
Mouse: Logitech G502 | Keyboard: Corsair K70 MX Brown | Audio: Sennheiser HD 558
i changed it 2 days ago with arctic silver 5 and the ambient temp is ~25
and you are right the temp of TMPIN3 is pretty okey but im concerning because is fluctuating fast from 33 idle to 45 while im web browsing, even when im starting skype or speedfan it goes to 45-50.
On Aida64 VRM temp is 52 MAX
It should have cured properly then. Although the instructions does specify 200 hours break-in time.
Only Asus, or experimentation, will be able to tell you where that sensor is. AIDA64 has mislabeled sensors in the past.
