Client is not giving me cpu workloads
Solved by tobben,
Depends on what gpu's you have and
how many.
The -1 default setting is abit of a funny
thing. Uneven numbers don't get any
work units. But assuming most people
have one gpu, the client will by default
use an uneven number, making you
non-eligible for most work.
They should probably fix that.. at any rate!
Since you have a hyperthreaded i7 with
8 threads, and probably between 1-2
gpu's, i would set it to 6 threads.
Announcements
Featured Topics
kodokuj ·
Posted in Graphics Cards2 -
Repoball ·
Posted in Troubleshooting2 -
OybeX3D ·
Posted in Operating Systems0 -
3
2
TridentTank88 ·
play_circle_filled
Latest From ShortCircuit:
Lian-Li, do this on all of your cases! - Lian-Li O11D x Lamborghini
