I thought blower fan blow in one direction. How does it properly cool.
Listen if you care.
https://linustechtips.com/topic/66210-how-does-this-fan-work/
Fan spins.
(it will blow down and it will exhaust at both sides)
https://linustechtips.com/topic/66210-how-does-this-fan-work/#findComment-905105
It blows the air is the both directions, so to the front and the back as this card has 2 chips on it.
https://linustechtips.com/topic/66210-how-does-this-fan-work/#findComment-905106
It then makes me curious as to why something like a titan or 7970/280x/290x reference cards have the blower on the end.
Listen if you care.
https://linustechtips.com/topic/66210-how-does-this-fan-work/#findComment-905114
upload 3
fan draws air in through the fans motor axis and blows it outwards centrifugally (in this case primarily horizontally) across the fins and out the back, this leads to a cheap and effective design that gets the air out of the case and doesnt create a "wide" card the heatsink can also be 2 slots tall.
upload 1
fan draws air in through the fans motor axis and blows it outwards centrifugally accross the fins to either side of it over the top of both gpus, this leads to half the heat going out the back and half going into the case, this is relatively cheap (still one motor but more heat pipes and fins..) maintains a "slim" card and only a minor penalty in temperitures. again the heatsink can be 2 slots tall.
upload 2
This draws air in through the fans axis and blows it out the back behind the fans through the heatsink and disspates over the board/out the sides and to a MUCH less extent sometimes out the back, this is optimal for cooling and noise (excluding water) because a larger fan can move more air through more fins increasing cooling while minimising noise, the downside is it requires 2 fans and more space creating a larger card and hence it costs a bit more and the heatsink is now only 1 slot tall as the fans take up a slot themselfs unless you go tripple slot.which...yeah.
upload 4
this slowly pulls your pc along moving away from any heat generated whatsoever. (its actually a good cooler, bigger fans=better)
Falcon: Corsair 750D 8320at4.6ghz 1.3v | 4GB MSI Gaming R9-290 @1000/1250 | 2x8GB 2400mhz Kingston HyperX Beast | Asus ROG Crosshair V Formula | Antec H620 | Corsair RM750w | Crucial M500 240GB, Toshiba 2TB, DarkThemeMasterRace, my G3258 has an upgrade path, my fx8320 doesn't need one...total cost £840=cpu£105, board£65, ram£105, Cooler £20, GPU£200, PSU£88, SSD£75, HDD£57, case£125.
 CASE:-NZXT S340 Black, CPU:-FX8120 @4.2Ghz, COOLER:-CM Hyper 212 EVO, BOARD:-MSI 970 Gaming, RAM:-2x4gb 2400mhz Corsair Vengeance Pro, GPU: SLI EVGA GTX480's @700/1000, PSU:-Corsair CX600m, HDD:-WD green 160GB+2TB toshiba
CASE:-(probably) Cooltek U1, CPU:-G3258 @4.5ghx, COOLER:-stock(soon "MSI Dragon" AiO likely), BOARD:-MSI z87i ITX Gaming, RAM:-1x4gb 1333mhz Patriot, GPU: Asus DCU2 r9-270 OC@1000/1500mem, PSU:-Sweex 350w.., HDD:-WD Caviar Blue 640GB
CASE:-TBD, CPU:-Core2Quad QX9650 @4Ghz, COOLER:-OCZ 92mm tower thing, BOARD:-MSI p43-c51, RAM:-4x1GB 800mhz Corsair XMS2, GPU: Zotac GTX460se @800/1000, PSU:-OCZ600sxs, HDD:-WD green 160GBBlueJean-A
 CASE:-Black/Blue Sharkoon T9, CPU:-Phenom2 x4 B55 @3.6Ghz/1.4v, COOLER:-FX8320 Stock HSF, BOARD:-M5A78L-M/USB3, RAM:-4GB 1333mhz Kingston low profile at 1600mhz, GPU:-EVGA GTX285, PSU:-Antec TP550w modu, STORAGE:-240gb  M500+2TB Toshiba
CASE:-icute zl02-3g-bb, CPU:-Phenom2 X6 1055t @3.5Ghz, COOLER:-Stock, BOARD:-Asrock m3a UCC, RAM:2x2GB 1333mhz Zeppelin (thats yellow!), GPU: XFX 1GB HD6870xxx, PSU:-some 450 POS, HDD:-WD Scorpio blue 120GB
CASE:-Packard Bell iMedia X2424, Custom black/red Aerocool Xpredator fulltower, CPU's:-E5200, C2D [email protected]<script cf-hash='f9e31' type="text/javascript"> /* */</script>(so e8500), COOLER:-Scythe Big shuriken2 Rev B, BFG gtx260 sp216 OC, RAM:-tons..
Gigabyte GTX460, Gigabyte gt430,
GPU's:-GT210 1GB,  asus hd6670 1GB gddr5, XFX XXX 9600gt 512mb Alpha dog edition, few q6600's
PICTURES CASE:-CIT mars black+red, CPU:-Athlon K6 650mhz slot A, COOLER:-Stock, BOARD:-QDI Kinetiz 7a, RAM:-256+256+256MB 133mhz SDram, GPU:-inno3d geforce4 mx440 64mb, PSU:-E-Zcool 450w, STORAGE:-2x WD 40gb "black" drives,
CASE:-silver/red raidmax cobra, CPU:-Athlon64 4000+, COOLER:-BIG stock one, BOARD:-MSI something*, RAM:-(matched pair)2x1GB 400mhz ECC transcend, GPU:-ati 9800se@375core/325mem, PSU:-pfft, HDD:-2x maxtor 80gb,
PICTURES CASE:-silver/red raidmax cobra (another), CPU:-Pentium4 2.8ghz prescott, COOLER:-Artic Coolering Freezer4, BOARD:-DFI lanparty infinity 865 R2, RAM:-(matched pair)2x1GB 400mhz kingston, GPU:-ati 9550@375core/325mem, PSU:-pfft, HDD:-another 2x WD 80gb,
CASE:-ML110 G4, CPU:-xeon 4030, COOLER:-stock leaf blower, BOARD:-stock raid 771 board, RAM:-2x2GB 666mhz kingston ECC ddr2, GPU:-9400GT 1GB, PSU:-stock delta, RAID:-JMicron JMB363 card+onboard raid controller, HDD:-320gb hitachi OS, 2xMaxtor 160gb raid1, 500gb samsungSP, 160gb WD, LAPTOP:-Dell n5030, CPU:-replaced s*** cel900 with awesome C2D E8100, RAM:-2x2GB 1333mhz ddr3, HDD:-320gb, PHONE's:-LG optimus 3D (p920) on 2.3.5@300-600mhz de-clock (batteryFTW)
https://linustechtips.com/topic/66210-how-does-this-fan-work/#findComment-905187
then look at gtx 690,also dual gpu.
That doesnt use a blower style fan
Listen if you care.
https://linustechtips.com/topic/66210-how-does-this-fan-work/#findComment-905264
thanks for the information, its nice to see when people put some time into things.
Listen if you care.
https://linustechtips.com/topic/66210-how-does-this-fan-work/#findComment-905267
6990 suck air from back/top and exaust in front
gtx 690 sucks air from top exaust both sides
front for me would be where the ports are.
so you are right sry.so it seems that you know already
in this case (air exiting out both sides) the 690's fan acts as an impeller, i.e a centrifugal fan in the same way as the 6990.
so they both work the same.
the difference is the impeller on the 6990 relies on the expulsion of air out of the sides to create a vacuum which then draws air in, 100% of the air coming out of the fan is sideways through the fins.
The 690's axial fan/impeller pushes air down towards the pcb and to an extent sideways (lets say 50% down and 50% sideways), the air that hits the mount/pcb is then directed sideways, so they both do a pretty close job.
when i was learning about jet engines as a kid (like 12, man I feel old and I'm only 24..) i read that early engines like sir frank whittles were based on the impeller design much like a cars turbocharger which pushed air out the sides, mixed it burnt it in canisters and then it went back to the turbine..
later/modern jets use an axial design where the air comes in the front and carries on in a straight line.
from what ive read at the time...
centrifugal fans generate a more consistent pressure and hence were better for low speed aircraft (or lower fan speeds i guess).
axial flow fans are more efficient at higher speeds because they can move more air, (means when your fans ramp up they can cool better)
this is why aftermarket companies like xfx/gigabyte/msi etc use 2x axial fans instead of slapping on a sticker like they used to in the 8800gt/9800gt/gtx280 days.
you're welcome.
https://linustechtips.com/topic/66210-how-does-this-fan-work/#findComment-905660
