so i am getting paid soon and one of the plans I have is to add some LEDS to not only my desk but my kitchen as well and maybe some other place but i can't tell if i am to cut these strips and make more than one strip with this real of led's or if not what else i will need.
link to strip:
https://www.amazon.co.uk/TENLION-lights-strips-lighting-charger/dp/B01CHYPRP4/ref=sr_1_4?s=lighting&ie=UTF8&qid=1474075649&sr=1-4&keywords=led+strip
other palces such as my kitchen and front room to give a more warm and better lighting I'd prefer.
Current Build :
CASE: Fractal Design R4 w/Window CPU: Intel 4930K,  RAM: 16GB Ripjaws Z 2133Mhz  Cooling: H100i  MotherBoard: Asus P9x79 Pro , PSU: CS750M   Storage: 2x Samsung 840 Pro 256Gb , 1Tb Seagate Barracuda, 500GB WD Black,  Graphics: Gigabyte GTX 780 Windforce 3GB,  Monitors: AOC G2460PG ( G sync monitor), Edge10 24" 1080p , 24" 1680*1020p monitor ( LCD)  Microphone: Blue Yeti  Keyboard: Cougar 700k  Phone: Samsung Note 3  Headphones: Sennheiser HD598
Laptop:
 CPU:
4710MQ  Ram: 8GB 1600MHz Storage:120Gb 840 Evo + 1Tb 5400Rpm HDD  Graphics: GTX 850M 2GB   Screen: 1080p IPS
https://linustechtips.com/topic/661959-led-strips-uk/
link to strip:
Yes those are standard SMD5050 LED's which you can cut to length and wire or solder them up as needed, just note you will require another RGB LED controller if you plan to set them up in different areas.
-Moved to Hobby Electronics-
https://linustechtips.com/topic/661959-led-strips-uk/#findComment-8556501
okay, that's fine, but what about have different strips in the same room, am I gonna need more controllers for each strip? if so can u direct me in the right way, I know I am gonna need more than one transformer for each and I am gonna get a remote wireless switch for that but other things I don't know.
Current Build :
Laptop:
 CPU:
https://linustechtips.com/topic/661959-led-strips-uk/#findComment-8556533
You'll need something like this to control the strips if your cutting up the strip to use in different areas, with that you will want to source a regulated 12V power supply.
https://www.amazon.co.uk/Remote-Controller-Ribbon-Static-Features/dp/B00JRVSO38/ref=sr_1_5?s=lighting&ie=UTF8&qid=1474078177&sr=1-5
https://www.amazon.co.uk/Adapter-Connector-Strip-Light-Connect/dp/B00USQ3FMG/ref=pd_sim_60_3?ie=UTF8&psc=1&refRID=WS6XDBE53Y08KV123P81
https://linustechtips.com/topic/661959-led-strips-uk/#findComment-8556542
okay excellent start, the 12v transformers I am guessing also shouldn't be too hard to find.
When I comes to connectors it was recommended to go with these with the LED's (for the kitchen): https://www.amazon.co.uk/Connector-Adapter-Strip-Stripe-Waterproof/dp/B009P08T4U/ref=pd_bxgy_201_3?ie=UTF8&psc=1&refRID=A7D6JBFKT0WT1MMRHQ5N
Also, what do u think of using an extension cable to merge 2 5m cables into 10m and using a 10m transformer and 1 controller for one room? link:
https://www.amazon.co.uk/10m-Strip-Light-Extension-Cable/dp/B00DOGADJK/ref=pd_bxgy_201_2?ie=UTF8&psc=1&refRID=A7D6JBFKT0WT1MMRHQ5N
Current Build :
Laptop:
 CPU:
https://linustechtips.com/topic/661959-led-strips-uk/#findComment-8556600
You can buy premade extensions but it does require you to solder on those 4 pin connectors to the LED contacts when you cut them to length. If you want a quick overview of it I have a guide of it here under wiring up LED Strips:
https://linustechtips.com/topic/661959-led-strips-uk/#findComment-8556634
thanks appricated, i do wonder though do you think it is possible to solder or even merge to strips together in series or parallel?
Current Build :
Laptop:
 CPU:
https://linustechtips.com/topic/661959-led-strips-uk/#findComment-8556701
1 minute ago, SparkySamZa said:
-SNIP-
You can series and parallel the LED's together if you say want to have an extension lead and wire another strip to the end of the last one or two right beside each other. Just make sure to keep the wiring orientation correct as the 4 pins aren't keyed.
https://linustechtips.com/topic/661959-led-strips-uk/#findComment-8556720
