Go for the i3 6100 instead if your gaming. Also you get a better upgrade path in the future.
http://au.pcpartpicker.com/list/yBNh3F
CPU: i7 5930k  |  Motherboard: EVGA X99 Classified  |  RAM: 32 GB Crucial DDR4  |  GPU:  R9 290 Reference Tri-Crossfire w/Kraken g10 mod  | Case: Corsair 780t  |  Storage: Sandisk 960GB SSD, Crucial 960GB SSD, 128GB Sandisk SSD, Seagate 2TB Hard Drive, Seagate Archive Drive 8TB, HGST Deskstar 4TB  |  PSU: Rosewill Gold Lightning-1300, Display(s): Nixeus Vue 24"144Hz FreeSync, 50in TV, Yiynova MVP22U(V3) Tablet Monitor w/ Mechanical Arm  |  Cooling: Cosair H55, H105, 2*Kraken X41  |  Keyboard:  Rosewill Mechanical Brown Keyboard| Mouse: MX Master, G602  | Sound:  Sennheiser HD 700, Westone W40, SoundBlaster e5, Fiio e18
28 minutes ago, arrion said:
This is what I have put together thus far:
http://au.pcpartpicker.com/list/tyvygL
i just need some advice such as if something doesn't work or could be better
im already over budget so I will spend no more than the cost of these
thanks
That's way too many weak cores, go down to a dual or quad core.
Why are you looking at only getting one RAM stick?
1474409643.6492558
made a few edits:
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor  ($154.00 @ Shopping Express)
Motherboard: Asus H110M-E Micro ATX LGA1151 Motherboard  ($79.00 @ Shopping Express)
Memory: G.Skill NT Series 8GB (1 x 8GB) DDR4-2400 Memory  ($45.10 @ Newegg Australia)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($68.00 @ CPL Online)
Video Card: Sapphire Radeon RX 480 4GB NITRO+ 4G Video Card  ($359.00 @ Mwave Australia)
Case: Silverstone PS09B MicroATX Mid Tower Case  ($45.00 @ Umart)
Power Supply: XFX TS 550W 80+ Bronze Certified ATX Power Supply  ($79.00 @ PCCaseGear) far better than the VS you picked.
Total: $829.10
Generated by PCPartPicker 2016-09-17 10:58 AEST+1000
3 hours ago, arrion said:
My actual budget was meant to be AU$600-700 and I'm only getting one ram stick because my dad already bought it...
so you alr have the ram?
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($65.00 @ Shopping Express)
Video Card: Sapphire Radeon RX 470 4GB Video Card  ($289.00 @ Mwave Australia)
Case: BitFenix Comrade ATX Mid Tower Case  ($49.00 @ Mwave Australia)
Power Supply: Antec 500W ATX Power Supply  ($59.00 @ CPL Online) a decent unit from delta or fsp.
Total: $695.00
Generated by PCPartPicker 2016-09-17 17:32 AEST+1000
