[Solved] Low framerates despite low utilization
Solved by iLoiter,
I am going to assume that the CPU is bottlenecking your GPU. Even though game do use multiple cores, single threaded performance is usually the most important factor and the second, third and fourth cores (most of the time) are not carrying as much load. The reason why your CPU usage is around 50 percent is because the 1-2 cores on your amd phenom ii x4 b95 are probably being pushed at its limit.
Edit: What are your laptop specs? Also try reinstalling GPU drivers.
