Best Ultrawide Monitor Under 400$
Arpan46
Hi guys
Can you all suggest me a budget ultrawide monitor (25"+ size)  with a display port and great color reproduction (Good RGB rating) for gaming and adobe stuff and i guess asking for more than 60Hz refresh rate will be demanding!
Thank you
Do yourself a favor and DON'T get an 25" ultrawide. You are better of with a regular 24" 1080p. At least 29" is recommended
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
8 minutes ago, Arpan46 said:
Hi guys
Thank you
https://www.amazon.com/LG-29UM58-P-29IN-UltraWide-21/dp/B01B67KAQ4/ref=sr_1_1?ie=UTF8&qid=1474046574&sr=8-1&keywords=29+in+ultrawide
this is the one that i have
Main Rig | Personal Build | Windows 10 | R7 2700x 3.7~4.3ghz | ASUS ROG Strix B450-I | 16gb DDR4 3200mhz | GTX 1080 FE | Coolermaster Elite 130 | Corsair H60 | WD Blue SN500 500GB NVMe SSD + 1tb WD Green HDD + 1tb WD Blue HDD
Laptop | HP m6-w102dx | Windows 10 | i7-5500u 2.4~3.0ghz | 8gb DDR3L | GT 930m 2gb| 120gb Sandisk SSD
Phone | Pixel 3 | Verizon | 64gb
10 minutes ago, Arpan46 said:
Hi guys
Thank you
https://www.amazon.com/LG-UltraWide-Gaming-Monitor-34UM57-P/dp/B011ESXHBA/ref=sr_1_4?s=pc&ie=UTF8&qid=1474046684&sr=1-4&keywords=ultrawide
this one is good as well. its a bit larger
The LG 29UM68-P looks good, currently eyeing that monitor for my setup.
Frost | 7700K @ 4.9GHz 1.36v, delidded | Asus DUAL GTX 1060 6GB OC | Corsair LPX 16GB DDR4 2800MHz | Samsung 960 EVO 250GB SSD + Toshiba 1TB HDD + Toshiba 2TB HDD + Samsung 860 EVO 1TB SSD for macOS | Asus PRIME Z270-A | Fractal Design Celsius S24 | Seasonic M12-II 620W PSU | Corsair 400C White | NZXT Hue+
Samsung Galaxy S8 | Stock
Ticwatch E (Black) | Ticwatch Brown Leather Strap
I wouldn't look at a 34" that isn't 1440, pixel density is too low at 1080.
5950 - 3090 - 32gb - Aorus FV43U - Steam Deck - Fuji xPro 3 - Olympus OM1 n
okay. but any specific model?
yeah, it is a good one
