I just finished building a PC with X99 motherboard. It didn't post so i checked the CPU and when I pulled out the CPU what do I find? One of the CPU corners was bend. I bent it back and place it in the socket again. Surprisingly it is working even after being bent. No problems so far, but i still can't explain to myself how the CPU got bent. It was in perfect condition before placing it in the socket and it was seated perfectly. It looks like it got bend when closing the 2 socket levers. It passed all the stress test i did and looks like it's working fine. Can there be some problems with a bend CPU?
i7 6800K
Corsair H110i GT
Asus ROG Strix X99 Gaming
Corsair Vengeance LPX (4x4GB) 3200MHz
Samsung 850 EVO 500GB
Seagate Barracuda 3TB
R9 270X
NZXT H440 (Black/Red) 2015 Edition
EVGA SuperNOVA P2 850W
BenQ XL2411Z
https://linustechtips.com/topic/661650-bent-cpu-corner/
Sure there can, but if you tested the CPU and it works fine, I wouldn't worry about it much further.
Maybe run some CPU specific benchmarks like Cinebench R15 and the like.  As long as it's performing normal, you should be good.
https://linustechtips.com/topic/661650-bent-cpu-corner/#findComment-8553056
Cinebench R15 shows exactly what the performance should be, but an AIDA64 memory & cache benchmark shows slightly higher L1, L2 & L3 latencies. Is it because of the bending, because my CPU's core and north bridge are not overclocked or it's completely normal?
4 minutes ago, Kantor said:
what do you mean it was bent do you mean the heat spreader was bent.
No, I mean that one of the bottom of the CPU corners was bent.
i7 6800K
Corsair H110i GT
R9 270X
BenQ XL2411Z
https://linustechtips.com/topic/661650-bent-cpu-corner/#findComment-8553085
Your L1, L2 & L3 are right where they should be.
https://linustechtips.com/topic/661650-bent-cpu-corner/#findComment-8553109
OK thank you, because I thought all of the CPU's should have 0.9ns L1 latency (at least that's what I saw from most people, even my other PC with 6600K has 0.9ns L1 latency)
i7 6800K
Corsair H110i GT
R9 270X
BenQ XL2411Z
https://linustechtips.com/topic/661650-bent-cpu-corner/#findComment-8553135
I have 1 more question - my RAM is 3200MHz, but Windows Task Manager shows it's running in 2133MHz. CPU-Z, AIDA64 and HWiNFO64 all show the correct speed (3200MHz). What may be causing that error?
i7 6800K
Corsair H110i GT
R9 270X
BenQ XL2411Z
https://linustechtips.com/topic/661650-bent-cpu-corner/#findComment-8553475
Disregard what you see in the Task Manager.  It reports the stock memory speed for that platform, not actual speed.
https://linustechtips.com/topic/661650-bent-cpu-corner/#findComment-8553511
OK, thank you for your answer. HWiNFO64 shows my RAM clock is 1600MHz (which is what it should be) and but shows 1600 = 24 x 66.7, but my bus is not 66.7MHz it's 100MHz. Is this also because of X99 platform?
i7 6800K
Corsair H110i GT
R9 270X
BenQ XL2411Z
https://linustechtips.com/topic/661650-bent-cpu-corner/#findComment-8553546
That's your memory divider at work.  Everything is fine.
You can definitely improve your memory bandwidth (AIDA64) through some CPU cache overclocking and tightening up timings, but as it stands, your system looks normal.
https://linustechtips.com/topic/661650-bent-cpu-corner/#findComment-8553570
Thank you all! I have one more question - in HWiNFO64 some sensors are not displayed. Is it normal or something with the motherboard?
i7 6800K
Corsair H110i GT
R9 270X
BenQ XL2411Z
https://linustechtips.com/topic/661650-bent-cpu-corner/#findComment-8558190
I just got reply by the HWiNFO support. It seems I have disabled them accidentally because of a warning that if I leave them enabled they could cause problems. I enabled them and all work fine now.
i7 6800K
Corsair H110i GT
R9 270X
BenQ XL2411Z
https://linustechtips.com/topic/661650-bent-cpu-corner/#findComment-8558913
I mean, if it's a new CPU you should just exchange it for one that has no issues even if it works fine. Unless you won the silicon lottery with a crazy good chip that might make it worth keeping, why not just get it replaced?
Primary PC-
CPU: Intel i7-6800k @ 4.2-4.4Ghz   CPU COOLER: Bequiet Dark Rock Pro 4   MOBO: MSI X99A SLI Plus   RAM: 32GB Corsair Vengeance LPX quad-channel DDR4-2800  GPU: EVGA GTX 1080 SC2 iCX   PSU: Corsair RM1000i   CASE: Corsair 750D Obsidian   SSDs: 500GB Samsung 960 Evo + 256GB Samsung 850 Pro   HDDs: Toshiba 3TB + Seagate 1TB   Monitors: Acer Predator XB271HUC 27" 2560x1440 (165Hz G-Sync)  +  LG 29UM57 29" 2560x1080   OS: Windows 10 Pro
Album
Other Systems:
Home HTPC/NAS-
CPU: AMD FX-8320 @ 4.4Ghz  MOBO: Gigabyte 990FXA-UD3   RAM: 16GB dual-channel DDR3-1600  GPU: Gigabyte GTX 760 OC   PSU: Rosewill 750W   CASE: Antec Gaming One   SSD: 120GB PNY CS1311   HDDs: WD Red 3TB + WD 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200 -or- Steam Link to Vizio M43C1 43" 4K TV  OS: Windows 10 Pro
Offsite NAS/VM Server-
CPU: 2x Xeon E5645 (12-core)  Model: Dell PowerEdge T610  RAM: 16GB DDR3-1333  PSUs: 2x 570W  SSDs: 8GB Kingston Boot FD + 32GB Sandisk Cache SSD   HDDs: WD Red 4TB + Seagate 2TB + Seagate 320GB   OS: FreeNAS 11+
Laptop-
CPU: Intel i7-3520M   Model: Dell Latitude E6530   RAM: 8GB dual-channel DDR3-1600  GPU: Nvidia NVS 5200M   SSD: 240GB TeamGroup L5   HDD: WD Black 320GB   Monitor: Samsung SyncMaster 2693HM 26" 1920x1200   OS: Windows 10 Pro
Having issues with a Corsair AIO? Possible fix here:
Are you getting weird fan behavior, speed fluctuations, and/or other issues with Link?
Are you running AIDA64, HWinfo, CAM, or HWmonitor? (ASUS suite & other monitoring software often have the same issue.)
Corsair Link has problems with some monitoring software so you may have to change some settings to get them to work smoothly.
-For AIDA64: First make sure you have the newest update installed, then, go to Preferences>Stability and make sure the "Corsair Link sensor support" box is checked and make sure the "Asetek LC sensor support" box is UNchecked.
-For HWinfo: manually disable all monitoring of the AIO sensors/components.
-For others: Disable any monitoring of Corsair AIO sensors.
That should fix the fan issue for some Corsair AIOs (H80i GT/v2, H110i GTX/H115i, H100i GTX and others made by Asetek). The problem is bad coding in Link that fights for AIO control with other programs. You can test if this worked by setting the fan speed in Link to 100%, if it doesn't fluctuate you are set and can change the curve to whatever. If that doesn't work or you're still having other issues then you probably still have a monitoring software interfering with the AIO/Link communications, find what it is and disable it.
https://linustechtips.com/topic/661650-bent-cpu-corner/#findComment-8558962
It's fairly new - I bought it 1 month ago. I contacted Intel Warranty Center and explained how it got bend -  the CPU was seated 100% perfectly in the socket and when I closed the 2 socket levers it got bend, I don't know how it happened and can't explain it to myself. They said it's user inflicted damage and depending on the bend they MIGHT be able to replace it under warranty, but they want a picture of the CPU and I'm too scared to pull it out of the socket because I might finish it. If I was 100% sure that they would replace it I was going to pull it right away and don't care at all, but what if I pull it out & it doesn't work anymore and they don't replace it? I'm just not risking it. The bend is not that light, the CPU is cracked a little on the place it got bent.
As for the silicon lottery I don't know if I won it. It can overclock to 4.2GHz with 1.23V Core Voltage and I didn't try to overclock it higher than that.
i7 6800K
Corsair H110i GT
R9 270X
BenQ XL2411Z
https://linustechtips.com/topic/661650-bent-cpu-corner/#findComment-8559584
Any advices? Is there any chance they are going to replace it or I'm out of luck?
i7 6800K
Corsair H110i GT
R9 270X
BenQ XL2411Z
https://linustechtips.com/topic/661650-bent-cpu-corner/#findComment-8570872
It may fail early. Do you have pictures of how it was bent?
ENCRYPTION IS NOT A CRIME
https://linustechtips.com/topic/661650-bent-cpu-corner/#findComment-8571013
No, from Intel Warranty Center told me to take pictures of the CPU and send them, but I'm very scared to pull the CPU out of the socket. I asked them If it was enough to take a picture of the CPU while in the socket.
i7 6800K
Corsair H110i GT
R9 270X
BenQ XL2411Z
https://linustechtips.com/topic/661650-bent-cpu-corner/#findComment-8571204
  • 1 year later...
Hey I too have got my CPU bent out of nowhere. Like before placing it into the socket it was completely normal but after that it had somehow bent automatically. Should I try to bent it back and put it into the socket? Are their chances it will damage the motherboard too? It seriously got bent out of nowhere. Also @kosamchetoo I would like to know how much was ur CPU bent. Check out the pics of my g4560 and tell if ur CPU was bent a bit less harshly than this. Some help would be seriously appreciated.
https://linustechtips.com/topic/661650-bent-cpu-corner/#findComment-11741608
That looks really bad. I wouldn't recommend try to put it into the socket.
Intel Core i9-9980XE 18c/36t, Asus TUF X299 Mark 1, 128GB DDR4 3200MHz, Palit RTX 5070, 2TB 970 EVO Plus, 2TB SN570, 8TB HDD, Meshify 2
PC 2: AMD Ryzen 7 3700X 8c/16t, MSI X470 Carbon, 32GB DDR4 2666MHz, Asus GTX 1080 Strix, 512GB Samsung PM981, 1TB Crucial MX500, Fractal Define R4
Old PC: Intel Xeon X5670 6c/12t @ 4.40GHz, Asus P6X58D-E, 48GB DDR3 1600MHz, EVGA GTX 970 ACX 2.0, 500GB, 250GB & 120GB SSD, 10TB & 2x 4TB HDD, Fractal Define R5
PC 3: Intel Xeon E5-2690 8c/16t @ 3.3-3.8GHz, ThinkStation S30 (C602/X79), 64GB (4x 16GB) DDR3 1600MHz, Asus GeForce GTX 960 Turbo OC, 1TB Crucial MX500
Laptop: ThinkPad T440p, Intel Core i7-4800MQ 4c/8t @ 2.7-3.7GHz, 16GB DDR3 1600MHz, GeForce GT 730M (GPU: 1006MHz MEM: 1151MHz), 2TB SSD, 14" 1080p IPS, 100Wh battery
Phone: Samsung Galaxy S23 256GB Watch: Samsung Galaxy Watch7 44mm LTE
General X58 Xeon/i7 discussion
Some other PC's:
Some of the specs of these systems might not be up to date
Z77: Intel Core i7-3770 4c/8t @ 4.22-4.43GHz, Asus P8Z77-V LK, 32GB DDR3 1648MHz, Asus RX 470 Strix, 1TB & 250GB Crucial MX500 and 3x 500GB HDD
PC 4: Intel Xeon X5675 6c/12t @ 3.07-3.47GHz, HP 0B4Ch (X58), 12GB DDR3 1333MHz, Asus GeForce GTX 660 DC2, 240GB & 120GB SSD, 1TB HDD
PC 5: Intel Xeon W3550 @ 3.07GHz, HP (X58), 8GB DDR3, NVIDIA GeForce GT 640 (GPU: 1050MHz MEM: 1250MHz), 120GB SSD, 2TB, 1TB and 500GB HDD
PC 6: Intel Core2 Quad Q9550 @ 3.8GHz, Asus P5KC, 8GB DDR2, NVIDIA GeForce GTX 470, 120GB SSD and 500GB HDD
HTPC: Intel Core2 Quad Q6600 @ 3.0GHz, HP DC7900SFF, 8GB DDR2 800MHz, Asus Radeon HD 6570, 240GB SSD and 3TB HDD
WinXP PC: Intel Core2 Duo E6300 @ 2.33GHz, Asus P5B, 2GB DDR2 667MHz, NVIDIA GeForce 8500 GT, 32GB SSD and 80GB HDD
RetroPC: Intel Pentium 4 HT @ 3.0GHz, Gigabyte GA-8SGXLFS, 2gb DDR1, ATi Radeon 9800 Pro, 2x 40gb HDD
My first PC: Intel Celeron 333MHz, Diamond Micronics C400, 384mb RAM, Diamond Viper V550 (NVIDIA Riva TNT), 6gb and 8gb HDD
Server: 2x Intel Xeon E5420, Dell PowerEdge 2950, 32gb DDR2, ATI ES1000, 4x 146gb SAS
Dual Opteron PC: 2x 6-core AMD Opteron 2419EE, HP XW9400, 32GB DDR2, ATI Radeon 3650, 500gb HDD
Core2 Duo PC: Intel Core2 Duo E8400, HP DC7800, 4gb DDR2, NVIDIA Quadro FX1700, 1tb and 80gb HDD
Athlon XP PC: AMD Athlon XP 2400+, MSI something, 1,5gb DDR1, ATI Radeon 9200, 40gb HDD
Thinkpad: Intel Core2 Duo T7200, Lenovo Thinkpad T60, 4gb DDR2, ATI Mobility Radeon X1400, 1tb HDD
Pentium 3 PC: Intel Pentium 3 866MHz, Asus CUSL2-C, 512mb RAM, 3DFX VooDoo 3 2000 AGP
Laptop: Dell Latitude E6430, Intel Core i5-3210M, 6gb DDR3 1600MHz , Intel HD 4000, 250gb Samsung SSD 860 EVO, 1TB WD Blue HDD
Laptop: Latitude 3380, Intel Pentium Gold 4415U 2c/4t @ 2.3GHz, 8GB DDR4, Intel HD 610, 120GB SSD, 13.3" 768p TN, 56Wh battery
Phone: Huawei Honor 9 64GB + 256GB card Watch: Motorola Moto 360 1st Gen.
Laptop 2: ThinkPad T450, Intel Core i7-5600U 2c/4t @ 2.6-3.2GHz, 16GB DDR3 1600MHz, Intel HD 5500, 250GB SSD, 14" 900p TN, 24Wh + 72Wh batteries
https://linustechtips.com/topic/661650-bent-cpu-corner/#findComment-11741671
  • 1 month later...
I had actually accidentally done this to my G4560 jst about a week ago by misaligning the CPU to the socket (I know, stupid me)
I just thought, welp I most likely killed the CPU already, might as well try to bend it back and hope for the best, and miraculously, it was still alive and still working! A week later and no apparent issue, other than thermals jumping back an forth around 55-60c (not sure if that's normal)  but doesn't get hotter than that, and it's been 100% stable as well.
Potatoes are the bacon of vegetables... nuff' said
MOBO: Asrock H67DE3, CPU: Intel Core i5 2400 @3.1GHz, GPU: Asus GTS 450 DirectCU Silent, Ram: 16gb 1333MHz, HDD: WD 1TB Green, PSU: 500 watt
https://linustechtips.com/topic/661650-bent-cpu-corner/#findComment-11847158
