Displayport to HDMI problems
30 minutes ago, Maxxtraxx said:Hi All! Thank you in advance for your help here.
Here is my current system: 1440p display and GTX 1080 fe
I have been using a HDMI cable to connect to my display for years without any issues.
I just hooked up my HTC vive which uses HDMI so I had to switch to a displayport port to connect my monitor
My monitor is mounted to the wall and has very little space behind it thus requiring a right angle cable adapter (Example: Here)to hook up the cable and allow for a low profile installation, Easy, plenty available for HDMI
I cannot find a right angle Displayport adapter to be able to use a Displayport cable, so I bought a Displayport to HDMI adapter.
The monitor's default resolution is now listed as 1080p by the nvidia control panel and thusly all is fuzzy, I created a custom 1440p resolution and made no difference.
1: I am very much guessing when I say the problem is likely to do with the HDMI to DP conversion unless someone else can inform me otherwise.
2: I would greatly appreciate anyone who can direct me to a right angle DP adapter for a reasonable price. HDMI example of the style needed: Here
Thanks!
This is the adapter I use. It can handle higher resolutions, and will let you just use any HDMI cables which should help with cable selection for the right angle stuff.
