Depends on if you want to overclock it
A H75 will cool anything, much as any CPU cooler will do the job and even the one that comes with it.
Intel i5 6600k @ 4.5GHz | NZXT Kraken X52 | Asus Maximus VIII Hero | Asus ROG Strix GTX 1070 | 16GB DDR4 Corsair Dominator Platinum @ 3200MHz | CoolerMaster MasterCase 5
https://linustechtips.com/topic/661034-fx9590-cooling/#findComment-8546589
i do not. I will keep it stock. (i still want to be alive) The thing im worried about is that the CPU has 220W TDP
https://linustechtips.com/topic/661034-fx9590-cooling/#findComment-8546597
Waste of money on 5+ year old architecture and No. The H75 will not.  The FX9590 has a TDP of 220w, I doubt a single 120mm rad will be able to handle that.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/661034-fx9590-cooling/#findComment-8546598
Just now, zMeul said:
the H75 doesn't even support the AM3+ socket: http://www.corsair.com/en/hydro-series-h75-liquid-cpu-cooler
Well i'm glad you noticed that :P:P
https://linustechtips.com/topic/661034-fx9590-cooling/#findComment-8546618
2 minutes ago, BurneyThePleb said:
i can make it work.
Don't. You need a better cooler. My aircooler is more efficient than your single-rad H75, and while my cooler would support a 9590 without issues, your H75 is a bit of a stretch for that.
If you don't want to spend too much money, the cheapest option to cool that CPU would be this:
http://pcpartpicker.com/product/ZsL7YJ/thermalright-cpu-cooler-machox2limitededition
If you can spend more for a 240mm AIO, this is good price/perf wise:
http://pcpartpicker.com/product/CrDzK8/corsair-cpu-cooler-cw9060025ww
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/661034-fx9590-cooling/#findComment-8546634
15 minutes ago, BurneyThePleb said:
Since im a little bit psycho i decided to buy a FX 9590. Will Corsair H75 be enough to cool it safely ?
what motherboard do you plan to use?...cause this is where it's also gonna get very hot...you need a top end AM3+ board with a solid 8 phase VRM with beefy heatskinks to run these and at that point you,re getting the performance of a 5 gen old intel core i7...for about the price of a haswell or skylake core i7 and a z series motherboard which will obviously crush the amd fx in everything you an think of.
| CPU: Core i7-8700K @ 4.89ghz - 1.21v  Motherboard: Asus ROG STRIX Z370-E GAMING  CPU Cooler: Corsair H100i V2 |
| GPU: MSI RTX 3080Ti Ventus 3X OC  RAM: 32GB T-Force Delta RGB 3066mhz |
| Displays: Acer Predator XB270HU 1440p Gsync 144hz IPS Gaming monitor | Oculus Quest 3 VR
https://linustechtips.com/topic/661034-fx9590-cooling/#findComment-8546638
Thank you
https://linustechtips.com/topic/661034-fx9590-cooling/#findComment-8546639
Just now, BurneyThePleb said:
Thank you
You also need a proper, high-end motherboard as @i_build_nanosuits very accurately mentioned, what is your motherboard?
https://linustechtips.com/topic/661034-fx9590-cooling/#findComment-8546647
im going with Gigabyte 990FXA-UD5 R5
you already own the motherboard? and the CPU?
cause honestly...that's a very very poor choice for what you have to pay...and you,ll be stuck with it cause there is no upgrade path what so ever...and it's a pretty poor performer.
https://linustechtips.com/topic/661034-fx9590-cooling/#findComment-8546667
i dont. and im well aware that its terrible price for the performance.
https://linustechtips.com/topic/661034-fx9590-cooling/#findComment-8546673
then why are you buying it at this point...this late in the game too..?! i don't get it...
https://linustechtips.com/topic/661034-fx9590-cooling/#findComment-8546675
i just want to build it \_(シ)_/¯
alright man...have fun...i guess...you like to give a shot at cooling stupidly power hungry components?!
cause believe it or not...a gentlemen once came to the forum and said for him that was the shit...he had a FX-9370 with dual R9 290X in crossfire...and he said keeping them cool is a challenge and that he really enjoyed that part...
i'm the opposite i guess...the cooler and quieter it run the more i'm impressed...whatever float your boat i guess.
Good luck!
https://linustechtips.com/topic/661034-fx9590-cooling/#findComment-8546701
i'm the opposite i guess...the cooler and quieter it run the mroe i'm impressed...whatever float your boat i guess.
Good luck!
Exactly. Thank you
Also if everything fails my friend has a supply of liquid nitrogen.
https://linustechtips.com/topic/661034-fx9590-cooling/#findComment-8546710
1 minute ago, BurneyThePleb said:
Exactly. Thank you
Could you by any chance change your motherboard choice? I could recommend a better alternative.
https://linustechtips.com/topic/661034-fx9590-cooling/#findComment-8546720
Which one ?
Depends on the budget. Is that within the budget? http://pcpartpicker.com/product/xz4gXL/asus-motherboard-sabertooth990fxr20
It's basically the top motherboard for that chipset.
https://linustechtips.com/topic/661034-fx9590-cooling/#findComment-8546736
