Hey guys,
I am running Windows 2012 server R2 essentials with SQL express 2016, and a peculiar issue seems to persist.
In reliability monitor, sqlsqm.exe stops working at 2:59AM every night.  I'm using tekradius for a radius server and when sqlsqm.exe stops working, it stops the tekradius service as well.
I really need a solution to this issue if possible.
Thanks.
https://linustechtips.com/topic/660618-sql-issue-i-presume/
Could it be some kind of a scheduled task, that closes the applications for some reason? Is there anything in logs regarding why it stops working?
Could possibly be a backup solution and SQL becomes unable to access it when backup starts due to file in use?
Just some ideas, not sure if they could be the cause :P
HAL9000: AMD Ryzen 9 3900x | Noctua NH-D15 chromax.black | 32 GB Corsair Vengeance LPX DDR4 3200 MHz | Asus X570 Prime Pro | ASUS TUF 3080 Ti | 1 TB Samsung 970 Evo Plus + 1 TB Crucial MX500 + 6 TB WD RED | Corsair HX1000 | be quiet Pure Base 500DX | LG 34UM95 34" 3440x1440
Hydrogen server: Intel i3-10100 | Cryorig M9i | 64 GB Crucial Ballistix 3200MHz DDR4 | Gigabyte B560M-DS3H | 33 TB of storage | Fractal Design Define R5 | unRAID 6.9.2
Carbon server: Fujitsu PRIMERGY RX100 S7p | Xeon E3-1230 v2 | 16 GB DDR3 ECC | 60 GB Corsair SSD & 250 GB Samsung 850 Pro | Intel i340-T4 | ESXi 6.5.1
Big Mac cluster: 2x Raspberry Pi 2 Model B | 1x Raspberry Pi 3 Model B | 2x Raspberry Pi 3 Model B+
https://linustechtips.com/topic/660618-sql-issue-i-presume/#findComment-8546399
Granted I'd take a snapshot / backup before, but have you updated both SQL and the Server? Do you have a development environment experiencing the same issues?
What do you see in the windows event logs / SQL logs / tekradius logs at that time?
https://linustechtips.com/topic/660618-sql-issue-i-presume/#findComment-8547275
Also, my temp fix is setting the tekradius service to restart 5 min. after an error termination indefinitely, no matter what.  It has worked the last two nights, but sqlsqm.exe still crashes at the same time, making this temp fix required to keep it going.
Everything is up to date.
This is the crash info:
Source
sqlsqm.exe
Summary
Stopped working
Date
‎9/‎16/‎2016 2:59 AM
Status
Report sent
Description
Faulting Application Path:    C:\Program Files\Microsoft SQL Server\130\Shared\sqlsqm.exe
Problem signature
Problem Event Name:    APPCRASH
Application Name:    sqlsqm.exe
Application Version:    13.0.1601.5
Application Timestamp:    5724522b
Fault Module Name:    KERNELBASE.dll
Fault Module Version:    6.3.9600.18340
Fault Module Timestamp:    57366075
Exception Code:    e0434352
Exception Offset:    0000000000008a5c
OS Version:    6.3.9600.2.0.0.305.50
Locale ID:    1033
Additional Information 1:    f18a
Additional Information 2:    f18a865cd1cc89894e9d42aca5526392
Additional Information 3:    8881
Additional Information 4:    88811638e202fc9fa1febf5319f0ff4f
Extra information about the problem
Bucket ID:    3576f95d01606bd706a9a56c4fbd06fc (120499072079)
Nothing in the tekRadius logs...
In SQL logs, I don't really know what i'm looking for, but should this be looping like this?
2016-09-14 14:00:38.12 spid18s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [4] 'msdb'. XTP Engine version is 0.0.
2016-09-14 14:00:38.12 spid9s      [INFO] HkHostDbCtxt::Initialize(): Database ID: [32767] 'mssqlsystemresource'. XTP Engine version is 0.0.
2016-09-14 14:00:38.12 spid19s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 14:00:38.12 spid18s     Starting up database 'msdb'.
2016-09-14 14:00:38.12 spid19s     Starting up database 'TekRADIUS'.
2016-09-14 14:00:38.12 spid9s      Starting up database 'mssqlsystemresource'.
2016-09-14 14:00:38.14 spid19s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 14:00:38.14 spid9s      The resource database build version is 13.00.1601. This is an informational message only. No user action is required.
2016-09-14 14:00:38.14 spid18s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [4] 'msdb'. XTP Engine version is 0.0.
2016-09-14 14:00:38.14 spid9s      [INFO] HkHostDbCtxt::Initialize(): Database ID: [32767] 'mssqlsystemresource'. XTP Engine version is 0.0.
2016-09-14 14:00:38.17 spid9s      [INFO] HkHostDbCtxt::Initialize(): Database ID: [32767] 'mssqlsystemresource'. XTP Engine version is 0.0.
2016-09-14 14:00:38.18 spid18s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [4] 'msdb'. XTP Engine version is 0.0.
2016-09-14 14:00:38.19 spid19s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 14:00:38.22 spid9s      [INFO] HkHostDbCtxt::Initialize(): Database ID: [3] 'model'. XTP Engine version is 0.0.
2016-09-14 14:00:38.22 spid9s      Starting up database 'model'.
2016-09-14 14:00:38.23 spid9s      [INFO] HkHostDbCtxt::Initialize(): Database ID: [3] 'model'. XTP Engine version is 0.0.
2016-09-14 14:00:38.26 spid9s      Polybase feature disabled.
2016-09-14 14:00:38.26 spid9s      Clearing tempdb database.
2016-09-14 14:00:38.39 spid9s      [INFO] HkHostDbCtxt::Initialize(): Database ID: [2] 'tempdb'. XTP Engine version is 0.0.
2016-09-14 14:00:38.39 spid9s      Starting up database 'tempdb'.
2016-09-14 14:00:38.48 spid20s     The Service Broker endpoint is in disabled or stopped state.
2016-09-14 14:00:38.48 spid20s     The Database Mirroring endpoint is in disabled or stopped state.
2016-09-14 14:00:38.50 spid20s     Service Broker manager has started.
2016-09-14 14:00:38.59 spid5s      Recovery is complete. This is an informational message only. No user action is required.
2016-09-14 14:00:39.08 spid51      Using 'dbghelp.dll' version '4.0.5'
2016-09-14 14:00:39.37 spid51      [INFO] HkHostDbCtxt::Initialize(): Database ID: [5] 'ReportServer$SQLEXPRESS'. XTP Engine version is 0.0.
2016-09-14 14:00:39.37 spid51      Starting up database 'ReportServer$SQLEXPRESS'.
2016-09-14 14:00:39.43 spid51      [INFO] HkHostDbCtxt::Initialize(): Database ID: [5] 'ReportServer$SQLEXPRESS'. XTP Engine version is 0.0.
2016-09-14 14:00:39.44 spid51      [INFO] HkHostDbCtxt::Initialize(): Database ID: [5] 'ReportServer$SQLEXPRESS'. XTP Engine version is 0.0.
2016-09-14 14:00:39.46 spid51      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 14:00:39.46 spid51      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 14:00:39.47 spid51      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 14:00:39.49 spid51      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 14:00:40.24 spid14s     A new instance of the full-text filter daemon host process has been successfully started.
2016-09-14 14:00:44.81 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [5] 'ReportServer$SQLEXPRESS'. XTP Engine version is 0.0.
2016-09-14 14:00:44.81 spid52      Starting up database 'ReportServer$SQLEXPRESS'.
2016-09-14 14:00:44.82 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [5] 'ReportServer$SQLEXPRESS'. XTP Engine version is 0.0.
2016-09-14 14:00:45.06 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 14:00:45.06 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 14:00:45.07 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 14:00:45.40 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 14:00:45.40 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 14:00:45.41 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 14:04:08.89 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 14:04:08.89 spid53      Starting up database 'TekRADIUS'.
2016-09-14 14:04:08.91 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 14:10:45.22 spid51      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 14:10:45.22 spid51      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 14:10:45.23 spid51      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 14:10:45.25 spid51      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 14:10:45.45 spid51      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 14:10:45.45 spid51      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 14:10:45.46 spid51      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 14:10:45.48 spid51      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 14:12:23.97 spid55      [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 14:12:23.97 spid55      Starting up database 'TekRADIUS'.
2016-09-14 14:12:23.98 spid55      [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 14:12:24.01 spid55      [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 14:20:45.19 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 14:20:45.19 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 14:20:45.21 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 14:30:45.20 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 14:30:45.20 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 14:30:45.23 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 14:31:10.39 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 14:31:10.39 spid32s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 14:31:10.40 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 14:31:10.42 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 14:31:10.46 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 14:31:10.46 spid32s     Starting up database 'TekRADIUS'.
2016-09-14 14:31:10.47 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 14:31:10.49 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 14:40:45.21 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 14:40:45.21 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 14:40:45.22 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 14:40:45.24 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 14:50:45.22 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 14:50:45.22 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 14:50:45.23 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 14:50:45.25 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 15:00:45.23 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 15:00:45.23 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 15:00:45.24 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 15:00:45.26 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 15:01:12.48 spid35s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 15:01:12.48 spid35s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 15:01:12.49 spid35s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 15:01:12.51 spid35s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 15:01:12.55 spid35s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 15:01:12.55 spid35s     Starting up database 'TekRADIUS'.
2016-09-14 15:01:12.56 spid35s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 15:01:12.59 spid35s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 15:10:45.20 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 15:10:45.20 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 15:10:45.21 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 15:10:45.23 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 15:20:45.21 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 15:20:45.21 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 15:20:45.23 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 15:30:45.22 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 15:30:45.22 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 15:30:45.23 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 15:30:45.25 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 15:31:14.32 spid27s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 15:31:14.32 spid27s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 15:31:14.35 spid27s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 15:31:14.38 spid27s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 15:31:14.38 spid27s     Starting up database 'TekRADIUS'.
2016-09-14 15:31:14.39 spid27s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 15:31:14.41 spid27s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 15:40:45.21 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 15:40:45.21 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 15:40:45.22 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 15:40:45.24 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 15:50:45.23 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 15:50:45.23 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 15:50:45.25 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 16:00:45.25 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 16:00:45.25 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 16:00:45.27 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 16:01:16.45 spid10s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 16:01:16.45 spid10s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 16:01:16.48 spid10s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 16:01:16.51 spid10s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 16:01:16.51 spid10s     Starting up database 'TekRADIUS'.
2016-09-14 16:01:16.52 spid10s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 16:01:16.54 spid10s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 16:10:45.25 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 16:10:45.25 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 16:10:45.27 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 16:20:45.26 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 16:20:45.26 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 16:20:45.27 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 16:20:45.29 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 16:30:45.28 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 16:30:45.28 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 16:30:45.30 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 16:31:18.75 spid35s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 16:31:18.75 spid35s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 16:31:18.78 spid35s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 16:31:18.82 spid35s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 16:31:18.82 spid35s     Starting up database 'TekRADIUS'.
2016-09-14 16:31:18.86 spid35s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 16:40:45.28 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 16:40:45.28 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 16:40:45.31 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 16:50:45.28 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 16:50:45.28 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 16:50:45.29 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 16:50:45.31 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 17:00:45.29 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 17:00:45.29 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 17:00:45.30 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 17:00:45.32 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 17:01:21.01 spid33s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 17:01:21.01 spid33s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 17:01:21.04 spid33s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 17:01:21.08 spid33s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 17:01:21.08 spid33s     Starting up database 'TekRADIUS'.
2016-09-14 17:01:21.10 spid33s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 17:10:45.29 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 17:10:45.29 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 17:10:45.31 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 17:20:45.30 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 17:20:45.30 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 17:20:45.32 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 17:30:45.30 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 17:30:45.30 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 17:30:45.31 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 17:30:45.33 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 17:31:23.26 spid27s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 17:31:23.26 spid27s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 17:31:23.27 spid27s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 17:31:23.29 spid27s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 17:31:23.33 spid27s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 17:31:23.33 spid27s     Starting up database 'TekRADIUS'.
2016-09-14 17:31:23.34 spid27s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 17:31:23.36 spid27s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 17:40:45.31 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 17:40:45.31 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 17:40:45.32 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 17:40:45.34 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 17:50:45.31 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 17:50:45.31 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 17:50:45.32 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 17:50:45.34 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 18:00:45.32 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 18:00:45.32 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 18:00:45.33 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 18:00:45.35 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 18:01:25.50 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 18:01:25.50 spid28s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 18:01:25.53 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 18:01:25.57 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 18:01:25.57 spid28s     Starting up database 'TekRADIUS'.
2016-09-14 18:01:25.58 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 18:01:25.61 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 18:10:45.35 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 18:10:45.35 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 18:10:45.37 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 18:20:45.35 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 18:20:45.35 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 18:20:45.37 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 18:30:45.35 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 18:30:45.35 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 18:30:45.36 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 18:30:45.38 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 18:31:27.70 spid18s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 18:31:27.70 spid18s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 18:31:27.73 spid18s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 18:31:27.77 spid18s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 18:31:27.77 spid18s     Starting up database 'TekRADIUS'.
2016-09-14 18:31:27.79 spid18s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 18:40:45.36 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 18:40:45.36 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 18:40:45.37 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 18:40:45.39 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 18:50:45.37 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 18:50:45.37 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 18:50:45.38 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 18:50:45.40 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 19:00:45.39 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 19:00:45.39 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 19:00:45.41 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 19:01:29.82 spid27s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 19:01:29.82 spid27s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 19:01:29.83 spid27s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 19:01:29.85 spid27s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 19:01:29.89 spid27s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 19:01:29.89 spid27s     Starting up database 'TekRADIUS'.
2016-09-14 19:01:29.90 spid27s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 19:01:29.92 spid27s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 19:10:45.39 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 19:10:45.39 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 19:10:45.40 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 19:10:45.42 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 19:20:45.39 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 19:20:45.39 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 19:20:45.40 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 19:20:45.42 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 19:30:45.40 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 19:30:45.41 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 19:30:45.41 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 19:30:45.43 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 19:31:32.09 spid25s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 19:31:32.09 spid25s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 19:31:32.12 spid25s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 19:31:32.15 spid25s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 19:31:32.15 spid25s     Starting up database 'TekRADIUS'.
2016-09-14 19:31:32.16 spid25s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 19:31:32.18 spid25s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 19:40:45.41 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 19:40:45.41 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 19:40:45.42 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 19:40:45.44 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 19:50:45.43 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 19:50:45.43 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 19:50:45.44 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 19:50:45.46 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 20:00:45.44 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 20:00:45.44 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 20:00:45.46 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 20:01:34.18 spid27s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 20:01:34.18 spid27s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 20:01:34.19 spid27s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 20:01:34.21 spid27s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 20:01:34.25 spid27s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 20:01:34.25 spid27s     Starting up database 'TekRADIUS'.
2016-09-14 20:01:34.27 spid27s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 20:10:45.44 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 20:10:45.44 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 20:10:45.46 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 20:20:45.45 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 20:20:45.45 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 20:20:45.47 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 20:30:45.46 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 20:30:45.46 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 20:30:45.48 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 20:31:36.25 spid10s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 20:31:36.25 spid10s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 20:31:36.28 spid10s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 20:31:36.31 spid10s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 20:31:36.31 spid10s     Starting up database 'TekRADIUS'.
2016-09-14 20:31:36.32 spid10s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 20:31:36.34 spid10s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 20:40:45.46 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 20:40:45.46 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 20:40:45.47 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 20:40:45.49 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 20:50:45.46 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 20:50:45.46 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 20:50:45.47 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 20:50:45.49 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 21:00:45.47 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 21:00:45.47 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 21:00:45.49 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 21:01:38.27 spid39s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 21:01:38.27 spid39s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 21:01:38.28 spid39s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 21:01:38.30 spid39s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 21:01:38.34 spid39s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 21:01:38.34 spid39s     Starting up database 'TekRADIUS'.
2016-09-14 21:01:38.36 spid39s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 21:10:45.48 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 21:10:45.48 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 21:10:45.49 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 21:10:45.51 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 21:20:45.48 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 21:20:45.48 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 21:20:45.49 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 21:20:45.51 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 21:30:45.49 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 21:30:45.49 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 21:30:45.50 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 21:30:45.52 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 21:31:40.44 spid15s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 21:31:40.44 spid15s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 21:31:40.45 spid15s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 21:31:40.47 spid15s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 21:31:40.51 spid15s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 21:31:40.51 spid15s     Starting up database 'TekRADIUS'.
2016-09-14 21:31:40.53 spid15s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 21:40:45.50 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 21:40:45.50 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 21:40:45.51 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 21:40:45.53 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 21:50:45.50 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 21:50:45.50 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 21:50:45.51 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 21:50:45.53 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 22:00:45.51 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 22:00:45.51 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 22:00:45.52 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 22:00:45.54 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 22:01:42.61 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 22:01:42.61 spid32s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 22:01:42.62 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 22:01:42.64 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 22:01:42.67 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 22:01:42.67 spid32s     Starting up database 'TekRADIUS'.
2016-09-14 22:01:42.68 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 22:01:42.70 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 22:10:45.53 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 22:10:45.53 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 22:10:45.55 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 22:20:45.53 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 22:20:45.53 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 22:20:45.54 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 22:20:45.56 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 22:30:45.55 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 22:30:45.55 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 22:30:45.56 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 22:30:45.58 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 22:31:45.01 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 22:31:45.01 spid28s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 22:31:45.02 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 22:31:45.04 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 22:31:45.10 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 22:31:45.10 spid28s     Starting up database 'TekRADIUS'.
2016-09-14 22:31:45.11 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 22:31:45.14 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 22:40:45.55 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 22:40:45.55 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 22:40:45.56 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 22:40:45.58 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 22:50:45.57 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 22:50:45.57 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 22:50:45.59 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 23:00:45.57 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 23:00:45.57 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 23:00:45.59 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 23:01:47.14 spid39s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 23:01:47.14 spid39s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 23:01:47.17 spid39s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 23:01:47.20 spid39s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 23:01:47.20 spid39s     Starting up database 'TekRADIUS'.
2016-09-14 23:01:47.21 spid39s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 23:01:47.23 spid39s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 23:10:45.57 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 23:10:45.57 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 23:10:45.58 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 23:10:45.60 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 23:20:45.59 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 23:20:45.59 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 23:20:45.60 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 23:20:45.62 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 23:30:45.60 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 23:30:45.60 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 23:30:45.62 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 23:31:49.33 spid39s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 23:31:49.33 spid39s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 23:31:49.36 spid39s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 23:31:49.40 spid39s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 23:31:49.40 spid39s     Starting up database 'TekRADIUS'.
2016-09-14 23:31:49.42 spid39s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-14 23:40:45.59 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 23:40:45.59 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 23:40:45.60 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 23:40:45.62 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 23:50:45.60 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 23:50:45.60 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-14 23:50:45.61 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-14 23:50:45.63 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 00:00:45.60 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 00:00:45.60 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 00:00:45.61 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 00:00:45.63 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 00:01:51.45 spid36s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 00:01:51.45 spid36s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 00:01:51.46 spid36s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 00:01:51.48 spid36s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 00:01:51.51 spid36s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-15 00:01:51.51 spid36s     Starting up database 'TekRADIUS'.
2016-09-15 00:01:51.52 spid36s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-15 00:01:51.55 spid36s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-15 00:10:45.63 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 00:10:45.63 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 00:10:45.64 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 00:10:45.66 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 00:20:45.63 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 00:20:45.63 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 00:20:45.64 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 00:20:45.66 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 00:30:45.63 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 00:30:45.63 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 00:30:45.64 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 00:30:45.66 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 00:31:53.55 spid35s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 00:31:53.55 spid35s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 00:31:53.58 spid35s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 00:31:53.61 spid35s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-15 00:31:53.61 spid35s     Starting up database 'TekRADIUS'.
2016-09-15 00:31:53.62 spid35s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-15 00:31:53.64 spid35s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-15 00:40:45.63 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 00:40:45.63 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 00:40:45.65 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 00:50:45.63 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 00:50:45.63 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 00:50:45.64 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 00:50:45.66 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 01:00:45.64 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 01:00:45.64 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 01:00:45.65 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 01:00:45.67 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 01:01:55.59 spid39s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 01:01:55.59 spid39s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 01:01:55.60 spid39s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 01:01:55.62 spid39s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 01:01:55.66 spid39s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-15 01:01:55.66 spid39s     Starting up database 'TekRADIUS'.
2016-09-15 01:01:55.67 spid39s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-15 01:01:55.69 spid39s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-15 01:10:45.63 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 01:10:45.63 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 01:10:45.65 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 01:20:45.65 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 01:20:45.65 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 01:20:45.67 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 01:30:45.65 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 01:30:45.65 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 01:30:45.67 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 01:31:57.79 spid14s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 01:31:57.79 spid14s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 01:31:57.80 spid14s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 01:31:57.82 spid14s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 01:31:57.86 spid14s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-15 01:31:57.86 spid14s     Starting up database 'TekRADIUS'.
2016-09-15 01:31:57.87 spid14s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-15 01:31:57.89 spid14s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-15 01:40:45.65 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 01:40:45.65 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 01:40:45.66 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 01:40:45.68 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 01:50:45.66 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 01:50:45.67 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 01:50:45.67 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 01:50:45.69 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 01:59:58.90 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 01:59:58.90 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 01:59:58.92 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 01:59:59.14 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 01:59:59.14 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 01:59:59.17 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 02:00:45.68 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 02:00:45.68 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 02:00:45.70 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 02:00:46.49 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 02:00:46.49 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 02:00:46.50 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 02:00:46.52 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 02:00:56.62 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 02:00:56.62 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 02:00:56.63 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 02:00:56.65 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 02:01:59.83 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 02:01:59.83 spid32s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 02:01:59.84 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 02:01:59.86 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 02:01:59.90 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-15 02:01:59.90 spid32s     Starting up database 'TekRADIUS'.
2016-09-15 02:01:59.91 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-15 02:01:59.93 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-15 02:10:46.62 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 02:10:46.62 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 02:10:46.63 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 02:10:46.65 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 02:20:46.62 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 02:20:46.62 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 02:20:46.65 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 02:30:46.63 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 02:30:46.63 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 02:30:46.64 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 02:30:46.67 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 02:32:02.03 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 02:32:02.03 spid32s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 02:32:02.06 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 02:32:02.09 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-15 02:32:02.09 spid32s     Starting up database 'TekRADIUS'.
2016-09-15 02:32:02.10 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-15 02:32:02.12 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-15 02:40:46.64 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 02:40:46.65 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 02:40:46.65 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 02:40:46.68 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 02:50:46.65 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 02:50:46.65 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 02:50:46.66 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 02:50:46.68 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 03:00:46.66 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 03:00:46.66 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 03:00:46.68 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 03:02:04.15 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 03:02:04.15 spid28s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 03:02:04.16 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 03:02:04.18 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 03:02:04.22 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-15 03:02:04.22 spid28s     Starting up database 'TekRADIUS'.
2016-09-15 03:02:04.24 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-15 03:10:46.66 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 03:10:46.66 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 03:10:46.69 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 03:17:01.71 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-15 03:17:01.71 spid54      Starting up database 'TekRADIUS'.
2016-09-15 03:17:01.73 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [7] 'TekRADIUS'. XTP Engine version is 0.0.
2016-09-15 03:20:46.67 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 03:20:46.67 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 03:20:46.68 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 03:20:46.70 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 03:30:46.67 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 03:30:46.67 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 03:30:46.70 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 03:32:06.22 spid38s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 03:32:06.22 spid38s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 03:32:06.23 spid38s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 03:32:06.25 spid38s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 03:40:46.67 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 03:40:46.67 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 03:40:46.68 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 03:40:46.69 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 03:50:46.69 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 03:50:46.69 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 03:50:46.71 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 04:00:46.68 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 04:00:46.68 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 04:00:46.69 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 04:00:46.71 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 04:02:08.38 spid34s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 04:02:08.38 spid34s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 04:02:08.41 spid34s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 04:10:46.69 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 04:10:46.69 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 04:10:46.71 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 04:20:46.70 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 04:20:46.70 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 04:20:46.71 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 04:20:46.73 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 04:30:46.71 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 04:30:46.71 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 04:30:46.73 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 04:32:10.30 spid39s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 04:32:10.30 spid39s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 04:32:10.33 spid39s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 04:40:46.70 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 04:40:46.70 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 04:40:46.71 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 04:40:46.73 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 04:50:46.71 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 04:50:46.71 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 04:50:46.72 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 04:50:46.74 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 05:00:46.72 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 05:00:46.72 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 05:00:46.74 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 05:02:12.25 spid26s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 05:02:12.25 spid26s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 05:02:12.26 spid26s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 05:02:12.28 spid26s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 05:10:46.72 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 05:10:46.72 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 05:10:46.73 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 05:10:46.75 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 05:20:46.73 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 05:20:46.73 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 05:20:46.77 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 05:30:46.73 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 05:30:46.73 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 05:30:46.74 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 05:30:46.75 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 05:32:14.08 spid15s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 05:32:14.08 spid15s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 05:32:14.11 spid15s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 05:40:46.72 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 05:40:46.72 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 05:40:46.73 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 05:40:46.75 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 05:50:46.73 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 05:50:46.73 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 05:50:46.74 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 05:50:46.76 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 06:00:46.74 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 06:00:46.74 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 06:00:46.77 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 06:02:16.09 spid40s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 06:02:16.09 spid40s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 06:02:16.10 spid40s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 06:02:16.12 spid40s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 06:10:46.74 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 06:10:46.74 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 06:10:46.75 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 06:10:46.77 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 06:20:46.75 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 06:20:46.75 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 06:20:46.76 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 06:20:46.78 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 06:30:46.76 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 06:30:46.76 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 06:30:46.78 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 06:32:18.17 spid29s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 06:32:18.17 spid29s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 06:32:18.20 spid29s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 06:40:46.77 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 06:40:46.77 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 06:40:46.79 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 06:50:46.77 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 06:50:46.77 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 06:50:46.78 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 06:50:46.80 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 07:00:46.78 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 07:00:46.78 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 07:00:46.80 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 07:02:19.90 spid14s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 07:02:19.90 spid14s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 07:02:19.91 spid14s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 07:02:19.93 spid14s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 07:10:46.77 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 07:10:46.77 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 07:10:46.78 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 07:10:46.83 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 07:20:46.79 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 07:20:46.79 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 07:20:46.80 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 07:20:46.82 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 07:30:46.79 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 07:30:46.79 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 07:30:46.80 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 07:30:46.82 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 07:32:21.67 spid39s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 07:32:21.67 spid39s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 07:32:21.68 spid39s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 07:32:21.70 spid39s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 07:40:46.80 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 07:40:46.80 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 07:40:46.82 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 07:50:46.81 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 07:50:46.81 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 07:50:46.82 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 07:50:46.84 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 08:00:46.82 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 08:00:46.82 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 08:00:46.83 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 08:00:46.85 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 08:02:23.84 spid19s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 08:02:23.84 spid19s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 08:02:23.87 spid19s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 08:10:46.85 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 08:10:46.85 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 08:10:46.87 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 08:20:46.87 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 08:20:46.87 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 08:20:46.89 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 08:30:46.87 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 08:30:46.87 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 08:30:46.89 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 08:32:26.05 spid31s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 08:32:26.05 spid31s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 08:32:26.06 spid31s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 08:32:26.08 spid31s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 08:40:46.87 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 08:40:46.87 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 08:40:46.88 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 08:40:46.90 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 08:50:46.89 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 08:50:46.89 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 08:50:46.91 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 09:00:46.89 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 09:00:46.89 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 09:00:46.91 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 09:02:27.90 spid34s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 09:02:27.90 spid34s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 09:02:27.91 spid34s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 09:02:27.93 spid34s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 09:10:46.88 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 09:10:46.88 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 09:10:46.89 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 09:10:46.91 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 09:20:46.89 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 09:20:46.89 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 09:20:46.91 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 09:30:46.90 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 09:30:46.90 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 09:30:46.92 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 09:32:29.86 spid27s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 09:32:29.86 spid27s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 09:32:29.87 spid27s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 09:32:29.89 spid27s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 09:40:46.91 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 09:40:46.91 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 09:40:46.93 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 09:50:46.92 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 09:50:46.92 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 09:50:46.93 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 09:50:46.95 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 10:00:46.93 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 10:00:46.93 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 10:00:46.94 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 10:00:46.96 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 10:02:31.68 spid38s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 10:02:31.68 spid38s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 10:02:31.71 spid38s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 10:10:46.94 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 10:10:46.94 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 10:10:46.96 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 10:20:46.94 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 10:20:46.94 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 10:20:46.95 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 10:20:46.97 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 10:30:46.95 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 10:30:46.95 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 10:30:46.97 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 10:32:33.73 spid25s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 10:32:33.73 spid25s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 10:32:33.74 spid25s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 10:32:33.76 spid25s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 10:40:46.95 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 10:40:46.95 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 10:40:46.98 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 10:50:46.95 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 10:50:46.95 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 10:50:46.96 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 10:50:46.98 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 11:00:46.95 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 11:00:46.95 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 11:00:46.96 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 11:00:46.98 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 11:02:35.68 spid34s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 11:02:35.68 spid34s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 11:02:35.69 spid34s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 11:02:35.71 spid34s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 11:10:46.97 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 11:10:46.97 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 11:10:46.99 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 11:20:46.97 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 11:20:46.97 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 11:20:46.98 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 11:20:47.00 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 11:30:46.99 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 11:30:46.99 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 11:30:47.00 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 11:30:47.02 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 11:32:37.52 spid19s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 11:32:37.52 spid19s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 11:32:37.53 spid19s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 11:32:37.55 spid19s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 11:40:47.00 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 11:40:47.00 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 11:40:47.02 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 11:50:47.00 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 11:50:47.00 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 11:50:47.01 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 11:50:47.03 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 12:00:47.01 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 12:00:47.01 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 12:00:47.03 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 12:02:39.45 spid30s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 12:02:39.45 spid30s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 12:02:39.48 spid30s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 12:10:47.00 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 12:10:47.00 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 12:10:47.01 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 12:10:47.03 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 12:20:47.01 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 12:20:47.01 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 12:20:47.02 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 12:20:47.04 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 12:30:47.02 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 12:30:47.02 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 12:30:47.03 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 12:30:47.05 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 12:32:41.44 spid10s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 12:32:41.44 spid10s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 12:32:41.45 spid10s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 12:32:41.47 spid10s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 12:40:47.03 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 12:40:47.03 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 12:40:47.04 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 12:40:47.06 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 12:50:47.03 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 12:50:47.03 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 12:50:47.04 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 12:50:47.06 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 13:00:47.05 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 13:00:47.05 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 13:00:47.06 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 13:00:47.08 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 13:02:43.51 spid18s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 13:02:43.51 spid18s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 13:02:43.54 spid18s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 13:10:47.06 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 13:10:47.06 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 13:10:47.08 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 13:20:47.07 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 13:20:47.07 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 13:20:47.08 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 13:20:47.10 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 13:30:47.08 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 13:30:47.08 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 13:30:47.10 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 13:32:45.41 spid33s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 13:32:45.41 spid33s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 13:32:45.42 spid33s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 13:32:45.44 spid33s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 13:40:47.08 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 13:40:47.08 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 13:40:47.09 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 13:40:47.11 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 13:50:47.10 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 13:50:47.10 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 13:50:47.12 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 14:00:47.10 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 14:00:47.10 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 14:00:47.11 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 14:00:47.13 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 14:00:47.68 spid57      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 14:00:47.68 spid57      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 14:00:47.69 spid57      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 14:00:47.71 spid57      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 14:01:29.15 spid51      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 14:01:29.15 spid51      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 14:01:29.16 spid51      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 14:01:29.18 spid51      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 14:02:47.41 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 14:02:47.41 spid28s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 14:02:47.42 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 14:02:47.44 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 14:10:47.80 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 14:10:47.80 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 14:10:47.81 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 14:10:47.83 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 14:20:47.81 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 14:20:47.81 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 14:20:47.85 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 14:30:47.82 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 14:30:47.82 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 14:30:47.83 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 14:30:47.86 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 14:32:49.19 spid26s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 14:32:49.19 spid26s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 14:32:49.20 spid26s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 14:32:49.22 spid26s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 14:40:47.82 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 14:40:47.82 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 14:40:47.83 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 14:40:47.86 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 14:50:47.83 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 14:50:47.83 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 14:50:47.84 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 14:50:47.86 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 15:00:47.84 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 15:00:47.84 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 15:00:47.85 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 15:00:47.87 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 15:02:50.98 spid26s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 15:02:50.98 spid26s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 15:02:50.99 spid26s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 15:02:51.01 spid26s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 15:10:47.84 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 15:10:47.84 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 15:10:47.86 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 15:20:47.84 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 15:20:47.84 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 15:20:47.86 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 15:30:47.84 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 15:30:47.84 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 15:30:47.85 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 15:30:47.87 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 15:32:52.67 spid40s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 15:32:52.67 spid40s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 15:32:52.70 spid40s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 15:40:47.85 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 15:40:47.85 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 15:40:47.87 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 15:50:47.85 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 15:50:47.85 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 15:50:47.86 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 15:50:47.88 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 16:00:47.85 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 16:00:47.85 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 16:00:47.86 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 16:00:47.88 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 16:02:54.71 spid31s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 16:02:54.71 spid31s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 16:02:54.72 spid31s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 16:02:54.74 spid31s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 16:10:47.86 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 16:10:47.86 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 16:10:47.87 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 16:10:47.89 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 16:20:47.87 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 16:20:47.87 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 16:20:47.89 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 16:30:47.87 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 16:30:47.87 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 16:30:47.89 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 16:32:56.73 spid41s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 16:32:56.73 spid41s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 16:32:56.74 spid41s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 16:32:56.76 spid41s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 16:40:47.88 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 16:40:47.88 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 16:40:47.90 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 16:50:47.88 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 16:50:47.88 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 16:50:47.89 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 16:50:47.91 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 17:00:47.89 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 17:00:47.89 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 17:00:47.91 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 17:02:58.52 spid35s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 17:02:58.52 spid35s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 17:02:58.53 spid35s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 17:02:58.55 spid35s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 17:10:47.87 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 17:10:47.87 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 17:10:47.88 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 17:10:47.90 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 17:20:47.88 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 17:20:47.88 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 17:20:47.90 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 17:30:47.88 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 17:30:47.88 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 17:30:47.89 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 17:30:47.91 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 17:33:00.40 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 17:33:00.40 spid28s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 17:33:00.43 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 17:40:47.90 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 17:40:47.90 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 17:40:47.91 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 17:40:47.93 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 17:50:47.90 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 17:50:47.90 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 17:50:47.91 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 17:50:47.93 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 18:00:47.91 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 18:00:47.91 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 18:00:47.92 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 18:00:47.94 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 18:03:02.18 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 18:03:02.18 spid28s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 18:03:02.21 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 18:10:47.92 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 18:10:47.92 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 18:10:47.93 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 18:10:47.95 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 18:20:47.94 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 18:20:47.94 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 18:20:47.96 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 18:30:47.94 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 18:30:47.94 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 18:30:47.96 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 18:33:04.15 spid18s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 18:33:04.15 spid18s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 18:33:04.16 spid18s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 18:33:04.18 spid18s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 18:40:47.95 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 18:40:47.95 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 18:40:47.97 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 18:50:47.96 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 18:50:47.96 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 18:50:47.98 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 19:00:47.97 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 19:00:47.97 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 19:00:47.99 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 19:03:05.89 spid18s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 19:03:05.89 spid18s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 19:03:05.92 spid18s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 19:10:47.95 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 19:10:47.95 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 19:10:47.96 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 19:10:47.97 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 19:20:47.94 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 19:20:47.95 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 19:20:47.95 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 19:20:47.97 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 19:30:47.95 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 19:30:47.95 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 19:30:47.96 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 19:30:47.97 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 19:33:07.85 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 19:33:07.85 spid32s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 19:33:07.86 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 19:33:07.88 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 19:40:47.96 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 19:40:47.96 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 19:40:47.97 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 19:40:48.00 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 19:50:47.96 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 19:50:47.96 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 19:50:47.99 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 20:00:47.97 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 20:00:47.97 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 20:00:47.98 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 20:00:48.00 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 20:03:09.81 spid24s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 20:03:09.81 spid24s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 20:03:09.84 spid24s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 20:10:47.98 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 20:10:47.98 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 20:10:48.00 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 20:20:47.98 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 20:20:47.98 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 20:20:47.99 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 20:20:48.01 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 20:30:47.99 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 20:30:47.99 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 20:30:48.00 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 20:30:48.02 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 20:33:11.67 spid30s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 20:33:11.67 spid30s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 20:33:11.68 spid30s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 20:33:11.70 spid30s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 20:40:48.00 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 20:40:48.00 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 20:40:48.01 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 20:40:48.03 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 20:50:48.01 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 20:50:48.01 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 20:50:48.03 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 21:00:48.01 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 21:00:48.01 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 21:00:48.03 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 21:03:13.60 spid10s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 21:03:13.60 spid10s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 21:03:13.63 spid10s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 21:10:48.01 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 21:10:48.01 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 21:10:48.03 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 21:20:48.01 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 21:20:48.01 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 21:20:48.02 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 21:20:48.04 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 21:30:48.03 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 21:30:48.03 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 21:30:48.05 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 21:33:15.49 spid10s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 21:33:15.49 spid10s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 21:33:15.52 spid10s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 21:40:48.05 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 21:40:48.05 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 21:40:48.07 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 21:50:48.04 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 21:50:48.05 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 21:50:48.05 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 21:50:48.07 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 22:00:48.06 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 22:00:48.06 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 22:00:48.07 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 22:00:48.09 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 22:03:17.54 spid29s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 22:03:17.54 spid29s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 22:03:17.55 spid29s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 22:03:17.57 spid29s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 22:10:48.06 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 22:10:48.06 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 22:10:48.07 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 22:10:48.09 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 22:20:48.06 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 22:20:48.06 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 22:20:48.07 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 22:20:48.09 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 22:30:48.08 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 22:30:48.08 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 22:30:48.09 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 22:30:48.11 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 22:33:19.47 spid29s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 22:33:19.47 spid29s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 22:33:19.48 spid29s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 22:33:19.50 spid29s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 22:40:48.09 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 22:40:48.09 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 22:40:48.10 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 22:40:48.12 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 22:50:48.10 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 22:50:48.10 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 22:50:48.13 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 23:00:48.10 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 23:00:48.10 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 23:00:48.12 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 23:03:21.37 spid18s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 23:03:21.37 spid18s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 23:03:21.38 spid18s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 23:03:21.40 spid18s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 23:10:48.11 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 23:10:48.11 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 23:10:48.13 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 23:20:48.12 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 23:20:48.12 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 23:20:48.13 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 23:20:48.15 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 23:30:48.12 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 23:30:48.12 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 23:30:48.14 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 23:33:23.31 spid14s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 23:33:23.31 spid14s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 23:33:23.32 spid14s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 23:33:23.34 spid14s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 23:40:48.13 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 23:40:48.13 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 23:40:48.15 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 23:50:48.13 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 23:50:48.13 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-15 23:50:48.14 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-15 23:50:48.16 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 00:00:48.14 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 00:00:48.14 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 00:00:48.16 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 00:03:25.28 spid29s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 00:03:25.28 spid29s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 00:03:25.31 spid29s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 00:10:48.13 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 00:10:48.13 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 00:10:48.14 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 00:10:48.16 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 00:20:48.14 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 00:20:48.14 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 00:20:48.16 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 00:30:48.14 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 00:30:48.14 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 00:30:48.16 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 00:33:26.94 spid10s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 00:33:26.95 spid10s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 00:33:26.95 spid10s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 00:33:26.98 spid10s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 00:40:48.15 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 00:40:48.15 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 00:40:48.17 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 00:50:48.14 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 00:50:48.14 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 00:50:48.15 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 00:50:48.17 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 01:00:48.15 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 01:00:48.15 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 01:00:48.16 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 01:00:48.18 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 01:03:28.89 spid26s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 01:03:28.89 spid26s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 01:03:28.90 spid26s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 01:03:28.92 spid26s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 01:10:48.22 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 01:10:48.22 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 01:10:48.23 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 01:10:48.25 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 01:20:48.23 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 01:20:48.23 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 01:20:48.26 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 01:30:48.24 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 01:30:48.24 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 01:30:48.25 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 01:30:48.27 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 01:33:30.66 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 01:33:30.66 spid28s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 01:33:30.67 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 01:33:30.69 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 01:40:48.25 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 01:40:48.25 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 01:40:48.26 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 01:40:48.28 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 01:50:48.25 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 01:50:48.25 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 01:50:48.26 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 01:50:48.28 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 01:59:59.59 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 01:59:59.59 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 01:59:59.62 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 02:00:48.70 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 02:00:48.70 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 02:00:48.71 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 02:00:48.73 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 02:00:58.82 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 02:00:58.82 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 02:00:58.83 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 02:00:58.85 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 02:03:32.55 spid25s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 02:03:32.55 spid25s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 02:03:32.56 spid25s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 02:03:32.58 spid25s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 02:10:48.75 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 02:10:48.75 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 02:10:48.76 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 02:10:48.78 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 02:20:48.75 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 02:20:48.75 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 02:20:48.77 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 02:30:48.75 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 02:30:48.75 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 02:30:48.76 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 02:30:48.78 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 02:33:34.35 spid15s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 02:33:34.35 spid15s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 02:33:34.36 spid15s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 02:33:34.38 spid15s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 02:40:48.75 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 02:40:48.75 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 02:40:48.76 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 02:40:48.78 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 02:50:48.75 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 02:50:48.75 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 02:50:48.76 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 02:50:48.78 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 03:00:48.77 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 03:00:48.77 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 03:00:48.78 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 03:00:48.80 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 03:03:36.26 spid18s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 03:03:36.26 spid18s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 03:03:36.27 spid18s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 03:03:36.29 spid18s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 03:10:48.79 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 03:10:48.79 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 03:10:48.80 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 03:10:48.82 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 03:20:48.80 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 03:20:48.80 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 03:20:48.81 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 03:20:48.83 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 03:30:48.81 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 03:30:48.81 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 03:30:48.82 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 03:30:48.84 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 03:33:38.16 spid25s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 03:33:38.17 spid25s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 03:33:38.17 spid25s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 03:33:38.20 spid25s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 03:40:48.83 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 03:40:48.83 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 03:40:48.85 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 03:50:48.82 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 03:50:48.83 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 03:50:48.83 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 03:50:48.85 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 04:00:48.83 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 04:00:48.83 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 04:00:48.86 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 04:03:40.03 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 04:03:40.03 spid32s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 04:03:40.06 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 04:10:48.84 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 04:10:48.84 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 04:10:48.85 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 04:10:48.87 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 04:20:48.85 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 04:20:48.85 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 04:20:48.87 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 04:30:48.84 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 04:30:48.84 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 04:30:48.85 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 04:30:48.87 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 04:33:41.79 spid25s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 04:33:41.79 spid25s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 04:33:41.82 spid25s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 04:40:48.86 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 04:40:48.86 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 04:40:48.87 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 04:40:48.89 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 04:50:48.87 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 04:50:48.87 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 04:50:48.88 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 04:50:48.90 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 05:00:48.88 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 05:00:48.88 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 05:00:48.89 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 05:00:48.91 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 05:03:43.67 spid15s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 05:03:43.67 spid15s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 05:03:43.68 spid15s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 05:03:43.70 spid15s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 05:10:48.88 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 05:10:48.88 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 05:10:48.89 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 05:10:48.91 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 05:20:48.88 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 05:20:48.88 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 05:20:48.89 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 05:20:48.91 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 05:30:48.88 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 05:30:48.88 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 05:30:48.89 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 05:30:48.91 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 05:33:45.65 spid24s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 05:33:45.65 spid24s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 05:33:45.66 spid24s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 05:33:45.68 spid24s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 05:40:48.88 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 05:40:48.88 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 05:40:48.89 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 05:40:48.91 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 05:50:48.89 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 05:50:48.89 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 05:50:48.90 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 05:50:48.92 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 06:00:48.90 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 06:00:48.90 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 06:00:48.92 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 06:03:47.56 spid38s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 06:03:47.56 spid38s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 06:03:47.57 spid38s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 06:03:47.59 spid38s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 06:10:48.91 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 06:10:48.91 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 06:10:48.93 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 06:20:48.92 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 06:20:48.92 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 06:20:48.94 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 06:30:48.92 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 06:30:48.92 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 06:30:48.93 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 06:30:48.95 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 06:33:49.38 spid36s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 06:33:49.38 spid36s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 06:33:49.39 spid36s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 06:33:49.41 spid36s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 06:40:48.92 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 06:40:48.92 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 06:40:48.94 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 06:50:48.93 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 06:50:48.93 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 06:50:48.95 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 07:00:48.93 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 07:00:48.93 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 07:00:48.95 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 07:03:51.22 spid37s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 07:03:51.22 spid37s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 07:03:51.23 spid37s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 07:03:51.26 spid37s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 07:10:48.93 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 07:10:48.93 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 07:10:48.95 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 07:20:48.93 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 07:20:48.93 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 07:20:48.94 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 07:20:48.96 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 07:30:48.94 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 07:30:48.95 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 07:30:48.95 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 07:30:48.97 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 07:33:53.12 spid39s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 07:33:53.12 spid39s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 07:33:53.15 spid39s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 07:40:48.96 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 07:40:48.96 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 07:40:48.97 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 07:40:48.99 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 07:50:48.97 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 07:50:48.97 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 07:50:48.99 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 08:00:48.97 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 08:00:48.97 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 08:00:48.98 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 08:00:49.00 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 08:03:54.87 spid25s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 08:03:54.87 spid25s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 08:03:54.88 spid25s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 08:03:54.90 spid25s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 08:10:48.98 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 08:10:48.98 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 08:10:48.99 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 08:10:49.01 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 08:20:48.99 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 08:20:48.99 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 08:20:49.00 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 08:20:49.02 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 08:30:49.00 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 08:30:49.00 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 08:30:49.02 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 08:33:56.86 spid36s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 08:33:56.86 spid36s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 08:33:56.89 spid36s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 08:40:49.01 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 08:40:49.01 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 08:40:49.02 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 08:40:49.04 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 08:50:49.03 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 08:50:49.03 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 08:50:49.05 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 09:00:49.03 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 09:00:49.03 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 09:00:49.04 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 09:00:49.05 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 09:03:58.74 spid26s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 09:03:58.74 spid26s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 09:03:58.75 spid26s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 09:03:58.77 spid26s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 09:10:49.03 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 09:10:49.03 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 09:10:49.04 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 09:10:49.06 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 09:20:49.03 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 09:20:49.03 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 09:20:49.04 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 09:20:49.06 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 09:30:49.04 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 09:30:49.04 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 09:30:49.05 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 09:30:49.07 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 09:34:00.93 spid18s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 09:34:00.93 spid18s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 09:34:00.96 spid18s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 09:40:49.04 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 09:40:49.04 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 09:40:49.05 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 09:40:49.07 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 09:50:49.06 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 09:50:49.06 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 09:50:49.08 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 10:00:49.07 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 10:00:49.07 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 10:00:49.08 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 10:00:49.10 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 10:04:02.65 spid38s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 10:04:02.65 spid38s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 10:04:02.68 spid38s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 10:10:49.09 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 10:10:49.09 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 10:10:49.11 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 10:20:49.09 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 10:20:49.10 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 10:20:49.10 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 10:20:49.12 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 10:30:49.10 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 10:30:49.10 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 10:30:49.11 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 10:30:49.13 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 10:34:04.60 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 10:34:04.60 spid28s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 10:34:04.61 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 10:34:04.63 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 10:40:49.11 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 10:40:49.11 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 10:40:49.13 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 10:50:49.12 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 10:50:49.12 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 10:50:49.13 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 10:50:49.15 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 11:00:49.13 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 11:00:49.13 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 11:00:49.14 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 11:00:49.16 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 11:04:06.31 spid18s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 11:04:06.31 spid18s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 11:04:06.32 spid18s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 11:04:06.34 spid18s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 11:10:49.13 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 11:10:49.13 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 11:10:49.14 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 11:10:49.16 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 11:20:49.14 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 11:20:49.14 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 11:20:49.15 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 11:20:49.17 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 11:30:49.15 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 11:30:49.15 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 11:30:49.16 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 11:30:49.18 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 11:34:08.20 spid34s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 11:34:08.20 spid34s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 11:34:08.21 spid34s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 11:34:08.23 spid34s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 11:40:49.15 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 11:40:49.15 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 11:40:49.17 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 11:50:49.15 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 11:50:49.15 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 11:50:49.16 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 11:50:49.18 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 12:00:49.16 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 12:00:49.16 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 12:00:49.17 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 12:00:49.19 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 12:04:10.03 spid31s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 12:04:10.03 spid31s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 12:04:10.04 spid31s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 12:04:10.06 spid31s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 12:10:49.16 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 12:10:49.16 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 12:10:49.17 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 12:10:49.19 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 12:20:49.18 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 12:20:49.18 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 12:20:49.20 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 12:30:49.19 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 12:30:49.19 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 12:30:49.21 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 12:34:12.01 spid26s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 12:34:12.02 spid26s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 12:34:12.02 spid26s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 12:34:12.05 spid26s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 12:40:49.19 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 12:40:49.19 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 12:40:49.20 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 12:40:49.22 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 12:50:49.20 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 12:50:49.20 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 12:50:49.22 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 13:00:49.21 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 13:00:49.21 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 13:00:49.23 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 13:04:13.87 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 13:04:13.87 spid32s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 13:04:13.90 spid32s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 13:10:49.21 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 13:10:49.21 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 13:10:49.23 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 13:20:49.22 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 13:20:49.22 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 13:20:49.24 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 13:30:49.23 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 13:30:49.23 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 13:30:49.24 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 13:30:49.26 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 13:34:15.88 spid30s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 13:34:15.88 spid30s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 13:34:15.91 spid30s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 13:40:49.24 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 13:40:49.24 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 13:40:49.25 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 13:40:49.27 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 13:50:49.25 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 13:50:49.25 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 13:50:49.26 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 13:50:49.28 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 14:00:49.25 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 14:00:49.25 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 14:00:49.27 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 14:00:49.95 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 14:00:49.95 spid54      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 14:00:49.98 spid54      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 14:02:41.54 spid51      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 14:02:41.54 spid51      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 14:02:41.55 spid51      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 14:02:41.57 spid51      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 14:04:17.60 spid36s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 14:04:17.61 spid36s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 14:04:17.61 spid36s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 14:04:17.64 spid36s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 14:10:50.10 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 14:10:50.10 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 14:10:50.11 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 14:10:50.12 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 14:20:50.10 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 14:20:50.10 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 14:20:50.13 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 14:30:50.11 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 14:30:50.11 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 14:30:50.14 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 14:34:19.42 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 14:34:19.42 spid28s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 14:34:19.43 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 14:34:19.45 spid28s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 14:40:50.11 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 14:40:50.11 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 14:40:50.13 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 14:50:50.12 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 14:50:50.12 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 14:50:50.14 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 15:00:50.12 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 15:00:50.12 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 15:00:50.14 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 15:04:21.44 spid19s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 15:04:21.44 spid19s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 15:04:21.47 spid19s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 15:10:50.10 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 15:10:50.10 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 15:10:50.11 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 15:10:50.13 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 15:20:50.11 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 15:20:50.11 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 15:20:50.12 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 15:20:50.14 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 15:30:50.12 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 15:30:50.12 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 15:30:50.13 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 15:30:50.15 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 15:34:23.38 spid35s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 15:34:23.38 spid35s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 15:34:23.41 spid35s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 15:40:50.13 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 15:40:50.13 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 15:40:50.14 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 15:40:50.16 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 15:50:50.15 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 15:50:50.15 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 15:50:50.16 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 15:50:50.18 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 16:00:50.15 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 16:00:50.15 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 16:00:50.16 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 16:00:50.18 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 16:04:25.16 spid30s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 16:04:25.16 spid30s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 16:04:25.17 spid30s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 16:04:25.19 spid30s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 16:10:50.16 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 16:10:50.16 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 16:10:50.17 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 16:10:50.19 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 16:20:50.18 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 16:20:50.18 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 16:20:50.20 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 16:30:50.18 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 16:30:50.18 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 16:30:50.20 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 16:34:27.04 spid39s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 16:34:27.04 spid39s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 16:34:27.07 spid39s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 16:40:50.18 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 16:40:50.18 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 16:40:50.19 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 16:40:50.21 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 16:50:50.18 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 16:50:50.18 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 16:50:50.19 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 16:50:50.21 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 17:00:50.19 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 17:00:50.19 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 17:00:50.20 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 17:00:50.22 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 17:04:28.76 spid26s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 17:04:28.76 spid26s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 17:04:28.79 spid26s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 17:10:50.20 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 17:10:50.20 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 17:10:50.22 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 17:20:50.20 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 17:20:50.20 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 17:20:50.21 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 17:20:50.23 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 17:30:50.21 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 17:30:50.21 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 17:30:50.22 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 17:30:50.24 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 17:34:30.61 spid14s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 17:34:30.61 spid14s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 17:34:30.62 spid14s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 17:34:30.64 spid14s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 17:40:50.22 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 17:40:50.22 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 17:40:50.24 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 17:50:50.23 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 17:50:50.23 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 17:50:50.25 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 18:00:50.24 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 18:00:50.24 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 18:00:50.26 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 18:04:32.48 spid37s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 18:04:32.48 spid37s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 18:04:32.49 spid37s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 18:04:32.51 spid37s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 18:10:50.23 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 18:10:50.23 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 18:10:50.24 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 18:10:50.26 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 18:20:50.25 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 18:20:50.25 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 18:20:50.27 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 18:30:50.26 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 18:30:50.26 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 18:30:50.27 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 18:30:50.29 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 18:34:34.30 spid29s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 18:34:34.30 spid29s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 18:34:34.31 spid29s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 18:34:34.33 spid29s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 18:40:50.27 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 18:40:50.27 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 18:40:50.29 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 18:50:50.26 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 18:50:50.26 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 18:50:50.27 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 18:50:50.29 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 19:00:50.26 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 19:00:50.26 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 19:00:50.27 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 19:00:50.29 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 19:04:36.26 spid41s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 19:04:36.26 spid41s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 19:04:36.29 spid41s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 19:10:50.27 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 19:10:50.27 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 19:10:50.29 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 19:20:50.27 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 19:20:50.27 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 19:20:50.28 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 19:20:50.30 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 19:30:50.28 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 19:30:50.28 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 19:30:50.29 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 19:30:50.31 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 19:34:38.23 spid42s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 19:34:38.23 spid42s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 19:34:38.24 spid42s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 19:34:38.26 spid42s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 19:40:50.29 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 19:40:50.29 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 19:40:50.31 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 19:50:50.31 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 19:50:50.31 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 19:50:50.33 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 20:00:50.32 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 20:00:50.32 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 20:00:50.34 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 20:04:40.10 spid34s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 20:04:40.10 spid34s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 20:04:40.13 spid34s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 20:10:50.33 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 20:10:50.33 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 20:10:50.35 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 20:20:50.33 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 20:20:50.33 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 20:20:50.35 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 20:30:50.34 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 20:30:50.34 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 20:30:50.36 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 20:34:42.04 spid36s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 20:34:42.04 spid36s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 20:34:42.07 spid36s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 20:40:50.34 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 20:40:50.34 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 20:40:50.35 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 20:40:50.37 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 20:50:50.36 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 20:50:50.36 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 20:50:50.37 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 20:50:50.39 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 21:00:50.36 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 21:00:50.36 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 21:00:50.37 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 21:00:50.39 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 21:04:43.67 spid19s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 21:04:43.67 spid19s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 21:04:43.68 spid19s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 21:04:43.70 spid19s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 21:10:50.35 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 21:10:50.35 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 21:10:50.36 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 21:10:50.38 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 21:20:50.36 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 21:20:50.36 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 21:20:50.37 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 21:20:50.39 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 21:30:50.37 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 21:30:50.37 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 21:30:50.38 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 21:30:50.40 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 21:34:45.67 spid33s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 21:34:45.67 spid33s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 21:34:45.68 spid33s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 21:34:45.70 spid33s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 21:40:50.37 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 21:40:50.37 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 21:40:50.38 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 21:40:50.40 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 21:50:50.37 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 21:50:50.37 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 21:50:50.38 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 21:50:50.40 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 22:00:50.38 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 22:00:50.38 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 22:00:50.40 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 22:04:47.63 spid18s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 22:04:47.63 spid18s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 22:04:47.64 spid18s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 22:04:47.66 spid18s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 22:10:50.38 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 22:10:50.38 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 22:10:50.39 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 22:10:50.41 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 22:20:50.40 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 22:20:50.40 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 22:20:50.42 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 22:30:50.42 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 22:30:50.42 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 22:30:50.43 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 22:30:50.45 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 22:34:49.67 spid15s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 22:34:49.67 spid15s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 22:34:49.70 spid15s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 22:40:50.42 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 22:40:50.42 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 22:40:50.44 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 22:50:50.42 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 22:50:50.42 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 22:50:50.43 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 22:50:50.45 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 23:00:50.44 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 23:00:50.44 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 23:00:50.45 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 23:00:50.47 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 23:04:51.49 spid38s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 23:04:51.49 spid38s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 23:04:51.52 spid38s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 23:10:50.42 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 23:10:50.43 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 23:10:50.43 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 23:10:50.45 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 23:20:50.42 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 23:20:50.42 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 23:20:50.43 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 23:20:50.45 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 23:30:50.42 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 23:30:50.42 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 23:30:50.43 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 23:30:50.45 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 23:34:53.45 spid25s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 23:34:53.45 spid25s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 23:34:53.46 spid25s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 23:34:53.48 spid25s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 23:40:50.44 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 23:40:50.44 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 23:40:50.45 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 23:40:50.46 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 23:50:50.45 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 23:50:50.45 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-16 23:50:50.46 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-16 23:50:50.48 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 00:00:50.47 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 00:00:50.47 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-17 00:00:50.49 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 00:04:55.40 spid10s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 00:04:55.40 spid10s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-17 00:04:55.41 spid10s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 00:04:55.43 spid10s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 00:10:50.48 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 00:10:50.48 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-17 00:10:50.49 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 00:10:50.51 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 00:20:50.48 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 00:20:50.48 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-17 00:20:50.49 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 00:20:50.51 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 00:30:50.49 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 00:30:50.49 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-17 00:30:50.51 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 00:34:57.19 spid31s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 00:34:57.19 spid31s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-17 00:34:57.20 spid31s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 00:34:57.22 spid31s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 00:40:50.50 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 00:40:50.50 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-17 00:40:50.52 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 00:50:50.50 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 00:50:50.50 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-17 00:50:50.51 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 00:50:50.53 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 01:00:50.50 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 01:00:50.51 spid52      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-17 01:00:50.51 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 01:00:50.53 spid52      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 01:04:59.17 spid43s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 01:04:59.17 spid43s     Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-17 01:04:59.18 spid43s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 01:04:59.20 spid43s     [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 01:10:50.48 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 01:10:50.48 spid53      Starting up database 'ReportServer$SQLEXPRESSTempDB'.
2016-09-17 01:10:50.49 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
2016-09-17 01:10:50.51 spid53      [INFO] HkHostDbCtxt::Initialize(): Database ID: [6] 'ReportServer$SQLEXPRESSTempDB'. XTP Engine version is 0.0.
https://linustechtips.com/topic/660618-sql-issue-i-presume/#findComment-8557256
SQLSQM.exe sends logs to Microsoft when there is a crash and you have opt'd in to customer experience. It is a little weird that this particular exe is crashing at all.
Open SQL Management Studio and check the actual SQL logs.
Running the setup and doing a repair install may fix the issue, but check the SQL server logs first.
https://linustechtips.com/topic/660618-sql-issue-i-presume/#findComment-8557890
I opened SQL MS and checked all of the logs.  These are the only 5 errors relating to the event at 2:59.
(They are in backwards order with respect to time)
09/18/2016 03:00:01,Windows Error Reporting,Information,Fault bucket <c/> type 0<nl/>Event Name: APPCRASH<nl/>Response: Not available<nl/>Cab Id: 0<nl/><nl/>Problem signature:<nl/>P1: sqlsqm.exe<nl/>P2: 13.0.1601.5<nl/>P3: 5724522b<nl/>P4: KERNELBASE.dll<nl/>P5: 6.3.9600.18340<nl/>P6: 57366075<nl/>P7: e0434352<nl/>P8: 0000000000008a5c<nl/>P9: <nl/>P10: <nl/><nl/>Attached files:<nl/>C:\Users\PBC_Admin\AppData\Local\Temp\WER87B8.tmp.appcompat.txt<nl/>C:\Users\PBC_Admin\AppData\Local\Temp\WER87F7.tmp.WERInternalMetadata.xml<nl/>C:\ProgramData\Microsoft\Windows\WER\ReportQueue\AppCrash_sqlsqm.exe_86ee9f1cd984ac3353973f4f24bec084701facbb_b47262fa_cab_460d87f6\memory.hdmp<nl/>C:\ProgramData\Microsoft\Windows\WER\ReportQueue\AppCrash_sqlsqm.exe_86ee9f1cd984ac3353973f4f24bec084701facbb_b47262fa_cab_460d87f6\triagedump.dmp<nl/>WERGenerationLog.txt<nl/><nl/>These files may be available here:<nl/>C:\ProgramData\Microsoft\Windows\WER\ReportQueue\AppCrash_sqlsqm.exe_86ee9f1cd984ac3353973f4f24bec084701facbb_b47262fa_cab_460d87f6<nl/><nl/>Analysis symbol: <nl/>Rechecking for solution: 0<nl/>Report Id: 82e86b49-7d6d-11e6-80e1-0cc47ac04c87<nl/>Report Status: 96<nl/>Hashed bucket:,,,,,,,(0),1001,,PBCServer
09/18/2016 03:00:01,Windows Error Reporting,Information,Fault bucket <c/> type 0<nl/>Event Name: APPCRASH<nl/>Response: Not available<nl/>Cab Id: 0<nl/><nl/>Problem signature:<nl/>P1: sqlsqm.exe<nl/>P2: 13.0.1601.5<nl/>P3: 5724522b<nl/>P4: KERNELBASE.dll<nl/>P5: 6.3.9600.18340<nl/>P6: 57366075<nl/>P7: e0434352<nl/>P8: 0000000000008a5c<nl/>P9: <nl/>P10: <nl/><nl/>Attached files:<nl/>C:\Users\PBC_Admin\AppData\Local\Temp\WER87B8.tmp.appcompat.txt<nl/>C:\Users\PBC_Admin\AppData\Local\Temp\WER87F7.tmp.WERInternalMetadata.xml<nl/>C:\ProgramData\Microsoft\Windows\WER\ReportQueue\AppCrash_sqlsqm.exe_86ee9f1cd984ac3353973f4f24bec084701facbb_b47262fa_cab_460d87f6\memory.hdmp<nl/>C:\ProgramData\Microsoft\Windows\WER\ReportQueue\AppCrash_sqlsqm.exe_86ee9f1cd984ac3353973f4f24bec084701facbb_b47262fa_cab_460d87f6\triagedump.dmp<nl/>WERGenerationLog.txt<nl/><nl/>These files may be available here:<nl/>C:\ProgramData\Microsoft\Windows\WER\ReportQueue\AppCrash_sqlsqm.exe_86ee9f1cd984ac3353973f4f24bec084701facbb_b47262fa_cab_460d87f6<nl/><nl/>Analysis symbol: <nl/>Rechecking for solution: 0<nl/>Report Id: 82e86b49-7d6d-11e6-80e1-0cc47ac04c87<nl/>Report Status: 4<nl/>Hashed bucket:,,,,,,,(0),1001,,PBCServer
09/18/2016 02:59:59,Service Control Manager,Information,The Windows Error Reporting Service service entered the running state.,,,,,,,(0),7036,,PBCServer
09/18/2016 02:59:59,Application Error,Error,Faulting application name: sqlsqm.exe<c/> version: 13.0.1601.5<c/> time stamp: 0x5724522b<nl/>Faulting module name: KERNELBASE.dll<c/> version: 6.3.9600.18340<c/> time stamp: 0x57366075<nl/>Exception code: 0xe0434352<nl/>Fault offset: 0x0000000000008a5c<nl/>Faulting process id: 0x2864<nl/>Faulting application start time: 0x01d2117a4530f24f<nl/>Faulting application path: C:\Program Files\Microsoft SQL Server\130\Shared\sqlsqm.exe<nl/>Faulting module path: C:\Windows\system32\KERNELBASE.dll<nl/>Report Id: 82e86b49-7d6d-11e6-80e1-0cc47ac04c87<nl/>Faulting package full name: <nl/>Faulting package-relative application ID:,,,,,,,(100),1000,,PBCServer
09/18/2016 02:59:59,.NET Runtime,Error,Application: sqlsqm.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.IO.FileLoadException
   at Microsoft.SqlServer.Sqm.Launcher.Main(System.String[]),,,,,,,(0),1026,,PBCServer
Same 5 messages, same time, every night.
Also going to try setup/repair.
https://linustechtips.com/topic/660618-sql-issue-i-presume/#findComment-8562941
The first error is the one you want to look at. It's throwing an exception because a file it requires either can't be found or has incorrect perms. I would recommend you double check permissions and possibly reinstall .net or the sql server as a last resort.
https://linustechtips.com/topic/660618-sql-issue-i-presume/#findComment-8567421
On 15/09/2016 at 3:26 AM, ryan9298b2 said:
I am running Windows 2012 server R2 essentials with SQL express 2016,
dude thats beta (i think)
their is probely many bugs and if this is for a work place or office, you are better to stick with an older version of SLQ
also 2012 has been know not to work with newer server software made by microsoft, they have tried to fix this but they never did
****SORRY FOR MY ENGLISH IT'S REALLY TERRIBLE*****
Been married to my wife for 3 years now! Yay!
https://linustechtips.com/topic/660618-sql-issue-i-presume/#findComment-8568389
