Is it this?
https://linustechtips.com/topic/660393-benchmark-or-engine/#findComment-8539626
12 minutes ago, WittyNameHere said:
Yessss! Thank you! Do you know if anyone can download it or if it is referenced as a benchmark?
I can't find anything on downloading it, seems like it's just a tech demo they showed off.
It doesn't seem to be a benchmark either, because a benchmark always ends with showing off the 'score' (in points or fps) and this one doesn't.
https://linustechtips.com/topic/660393-benchmark-or-engine/#findComment-8539645
