2 minutes ago, foon-fork said:
This is for 3D modelling, rigging, sculpting, and rendering.
http://ca.pcpartpicker.com/list/XTdC6X
I'd switch the PSU for an EVGA GQ/B2/GS/G2 and be set.
https://linustechtips.com/topic/660289-my-very-first-build/#findComment-8538619
7 minutes ago, foon-fork said:
There's no window in my case, and the psu is overkill for the amount of power I'm drawing anyways.
There's more to PSUs than wattage and I'm referring to quality, thus EVGA B2/GS/GQ/G2 for you. That Cooler Master isn't as good as any of those.
https://linustechtips.com/topic/660289-my-very-first-build/#findComment-8538673
I'd suggest getting some Black 4TB instead. I know they're pricier but the write/reads are better even if you use RAID.
Cor Caeruleus Reborn v6
CPU: Intel - Core i7-8700K
CPU Cooler: be quiet! - PURE ROCK
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste
Motherboard: ASRock Z370 Extreme4
Memory: G.Skill TridentZ RGB 2x8GB 3200/14
Storage: Samsung - 850 EVO-Series 500GB 2.5" Solid State Drive
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive
Storage: Western Digital - Blue 2TB 3.5" 5400RPM Internal Hard Drive
Storage: Western Digital - BLACK SERIES 3TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA - 970 SSC ACX (1080 is in RMA)
Case: Fractal Design - Define R5 w/Window (Black) ATX Mid Tower Case
Power Supply: EVGA - SuperNOVA P2 750W with CableMod blue/black Pro Series
Optical Drive: LG - WH16NS40 Blu-Ray/DVD/CD Writer
Operating System: Microsoft - Windows 10 Pro OEM 64-bit and Linux Mint Serena
Keyboard: Logitech - G910 Orion Spectrum RGB Wired Gaming Keyboard
Mouse: Logitech - G502 Wired Optical Mouse
Headphones: Logitech - G430 7.1 Channel  Headset
Speakers: Logitech - Z506 155W 5.1ch Speakers
https://linustechtips.com/topic/660289-my-very-first-build/#findComment-8538725
I'll keep that in mind when I get another job.
Had to cheap out to make the build work somehow.
https://linustechtips.com/topic/660289-my-very-first-build/#findComment-8538734
I suggest Kinguin for your Windows 10. It's ~$30 CAD for the pro 64 bit version, as opposed to your $115.
Edit: Re-purpose this money for other parts, like a better HDD or Graphics card. (BTW what software do  you use? I've heard of some incompatibilities with the GTX 1000 Series and some 3D software (CUDA or something)).
Edited by bob51zhang
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
https://linustechtips.com/topic/660289-my-very-first-build/#findComment-8538740
1 minute ago, foon-fork said:
That'll be an upgrade once the cash starts to flow in.
The Seagate Barracuda or Hitachi Ultrastars would be better than those for your purposes.
https://linustechtips.com/topic/660289-my-very-first-build/#findComment-8538748
The PSU is the last thing you should be cheapening out on... you can scrap one HDD for now and easily add in another later. It's not so easy with the PSU and it's best to get a solid PSU now rather than later.
https://linustechtips.com/topic/660289-my-very-first-build/#findComment-8538782
16 minutes ago, foon-fork said:
Sorry to say that it's already been built :c
Ohh....
well I guess the PSU is fine now but I would have changed it beforehand. Why'd you not ask *before* building it?
https://linustechtips.com/topic/660289-my-very-first-build/#findComment-8538785
Just now, STRMfrmXMN said:
Ohh....
I was in a hurry to get this done before school started, and I needed some leftover cash after tuition.
Regardless, I could get a new power supply at any time.
https://linustechtips.com/topic/660289-my-very-first-build/#findComment-8538788
I thought you were going to be building this soon, the PSU is fine but I wanted to get you a better PSU for the money. You're fine now.
https://linustechtips.com/topic/660289-my-very-first-build/#findComment-8538800
