A small question I have
Solved by Yoinkerman,
This. Both the 2.4ghz and the 5gz should have their own wifi name and password. Just delete the 2.4ghz one from your list of networks. If for some reason they are both the same, log into your router and change one of them.
If the router has 2 separate connections then you just have to make sure that your PC is connected to the correct wireless network. I doubt you have bridged the connections, so I don't know how else Windows would "combine" the connections,
