Does this Build require "MLG" cooling?
I'm not that good with fans but I can answer one of your questions, your case comes with one pre installed LED fan in the rear, so with your budget I'd replace that instantly. I'd recommend getting 3 fans, one for exhaust and two for intake, or just buy two and have the led one at the front cos it looks cool. Sorry I cant give you recommendations, Im using the two that came with my case ATM.
Also, that cooler looks really ugly in my opinion.
9 minutes ago, NeoSk11zle said:
So I got my PC http://nz.pcpartpicker.com/list/zqBFsJ but I'm not sure if it the InWin 503 comes with fans, if not what fans should I get and how much? Also I live in New Zealand so everything here is a bit more expensive. Thanks.
It comes with one fan. I'd suggest to move it to the rear and install these at the front
http://pricespy.co.nz/product.php?p=2728271
CPU: Intel i7-4790K @ stock for now --- RAM: Corsair Vengeance 16Gb --- MOBO: Asus Maximus VII Formula --- GPU: MSI Gaming GTX 980ti --- PSU: Corsair AX860i  ---  Storage: Samsung 850 250gb(OS), 3x Western Digital Blue 3tb (one for game and programs, two for media), 3tb WD Green(somewhat backup) and a Crucial M550 120gb SSD (caching games and programs drive)  --- Case: Fractal Define R5 --- Cooler: Corsair H100i with Noctua 2000rpm, Industrial Fans --- OS: Windows 10 --- Monitor: Asus PB298q + AOC l2260SWD --- Mouse: Logitech G502 Spectrum --- Keyboard: Corsair K70 (Cherry MX Red) Red LED's --- Audio: Audio Engine A2's (yes the originals), Sennheiser HD 58x Jubilee Audio-Technica ATH-AD900x, Audio-Technica ATH-M50x, Ant Lion Mod Mic V4 --- Laptop: Dell XPS 9750
Anything for budget, don't give a flying fuck about how the cooler looks. lol.
Thnx!
the InWin comes with a rear red LED fan but I would recommend getting another one for an intake and exhaust case airflow config.
The fan mounting spots are as follows:
2 x 120mm Front Fan
1 x 120mm Rear Fan (Pre-installed LED)
1 x 120mm Bottom Fan
A fan I would recommend, if it were to be tucked away in the front of the case is a Corsair Air AF120 Performance fan.
Never have 2 intakes and one exhaust, that will generate static pressure which is not beneficial to a system. Balanced intakes and exhausts will, however, be better as there is constant airflow and warm air is replaced with cooler air.
The CPU is a locked skew which means you won't be overclocking, therefore using the stock cooler is the best option for your budget.
(the feels of 15% GST in NZ, I live in AU so the GST is 10%)
I suck a typing, preparw for typos.
Desktop
CPU: Ryzen 7 3700x MOBO: MSI X570-A Pro RAM: 32 GB Corsair DDR4
GPUS: Gigabyte GTX 1660ti OC 6G  CASE: Corsair Carbide 100R STORAGE: Samsung Evo 960 500GB, Crucial P1 M.2 NVME 1TB   PSU: Corsair CX550M CPU COOLER: Corsair H100x
LAPTOP
Apple Macbook Pro 13 M1 Pro
2 x 120mm Front Fan
Wait, does my cpu come with a cooler? and yeah won't be overclocking my non-k cpu! feel with the shitty GST 15%!!!!!!!!!!!!!!!!!!!!!!! kys John Key the donkey
so here are my fans http://nz.pcpartpicker.com/list/zZzHGf ut don't were to put them. Not much of a fan person. And yes I know another random person gave me an option.
Haha, yes your CPU will come with a cooler, we will have the same CPU if you get your build.
I was told a good joke about airports in NZ, ( The pilot of a flight to Australia from New Zealand shouted to the last passenger boarding, "Remember to turn off the lights in the airport as you board the aircraft!"
Desktop
LAPTOP
Looking at the description it comes with 1x 120mm LED fan in the exhaust. I personally loathe LED fans, but that always comes down to personal choice.
I would recommend putting 2x 120mm fans on the front as intake. I have some spare SP120 PWM quiet edition fans if you want, they are surplus to my requirements.
You don't need to run the intake and exhaust fans at the same RPM. Often intakes are more restricted than the exhaust.
Yes
That isn't a joke, we are serious about saving electricity here.
LOL
I'd say definitely add two intake fans. In no way do I see it being better to only use one to have matching intake/exhaust fan amounts. It's perfectly fine to have two fans at front instead of one, especially when they could be partially blocked by the 3.5 and 5.25 cages, as any extra intake air isn't going to just become hot and linger in the case, it'll either get sucked up by the exhaust fan or get pushed out anyway through the expansion slot holes or other more open crevices.
CPU: AMD Sempron 2400+ / MOBO: Abit NF7-S2G / GPU: WinFast A180BT 64MB / RAM: Mushkin DDR333 256MBx2 / HDD: Seagate Barracuda 7200RPM 120GB
ok(kk)  ( ͡° ͜ʖ ͡°)
I dont think you are Dankworthy enough to own some real mlg fans
Elemental
Intel i5 6500 @3.8ghz - 8GB HyperX - 600w Apex PSU - GTX 1060 G1 GIGABYTE 6GB - s340 Black - 240gb Toshiba Q300 - Cooler master TX3i - MSI z170-A PRO.
Old Build (sold for 290€)
Intel i3 540 @ 3.9ghz (On stock cooler, Hits 80c max) - 8gb ram - 500w power supply - P7H55-M LE  120gb SSD - Talius Drakko case
Project Frug 50$ Water loop
Laptops
13" Macbook Air - Alienware m14x r2 -  2009 15" Macbook Pro (I was give all of these and would never buy them myself)
Yes, it comes with a stock cooler and you don't need to buy an aftermarket one.
You could add a front or bottom intake: http://nz.pcpartpicker.com/product/bKFPxr/noctua-case-fan-nfs12bredux1200pwm
The i5 6500 comes with a stock cooler. The GAMMAXX 300 is a better cooling option but is not necessary. At full speed both coolers get fairly loud, the only difference is that the 300 has more surface area so it won't need to spin as fast to cool the CPU (in most cases).
You will want the intake and exhaust to be roughly the same, if possible slightly higher intake pressure. Replacing the single rear fan with a high airflow fan might make this about equal, but I have no experience with the fans the case comes with.
Intel Xeon 1650 V0 (4.4GHz @1.4V), ASRock X79 Extreme6, 32GB of HyperX 1866, Sapphire Nitro+ 5700XT, Silverstone Redline (black) RL05BB-W, Crucial MX500 500GB SSD, TeamGroup GX2 512GB SSD, WD AV-25 1TB 2.5" HDD with generic Chinese 120GB SSD as cache, x2 Seagate 2TB SSHD(RAID 0) with generic Chinese 240GB SSD as cache, SeaSonic Focus Plus Gold 850, x2 Acer H236HL, Acer V277U be quiet! Dark Rock Pro 4, Logitech K120, Tecknet "Gaming" mouse, Creative Inspire T2900, HyperX Cloud Flight Wireless headset, Windows 10 Pro 64 bit
Ok Thanks. I have never built a computer before and am planning to get the parts this Christmas or early next year.
