Ok so I have already purchased my ncase m1 and have received it. Now I am still on the fence about a lot of the internal components, specifically the psu. I was originally going to get the Silverstone SX700-LPT but the reviews appear to be extremely mixed, and on Newegg it only has 2 reviews and both are negative. I am also worried about clearance for the MSI GTX 1080 that I want to install because I have seen where people say that the cables coming out of PSU push down on the GPUs. So the other option is maybe the Silverstone SX600-G but I run into the same issues with people saying they fail quickly and it's incredibly noisy etc etc. Does anyone have experience with either one of these PSU and this case? In addition has anyone bothered to see if they can get shorter cables from cablemods that accommodate cleaner cable runs? I want to get the Z170I GAMING PRO AC motherboard. By the way I am also considering the Corsair SF600 PSU, but worry about the SFX-L issue.
http://pcpartpicker.com/list/qFFGPs
https://linustechtips.com/topic/658977-ncase-m1-power-supply/
5 minutes ago, d4thev said:
-SNIP-
The silverstone SFX units are decent but if you wanted some option you can always go for a 600W SFX unit Corsair has that is short and 100mm which should have decent clearance.
https://linustechtips.com/topic/658977-ncase-m1-power-supply/#findComment-8522434
