Can someone help me find a good deal for the "USB Rubber Ducky", here is an example for it. http://hakshop.myshopify.com/products/usb-rubber-ducky-deluxe It's really expencive though, like most things are if you buy them from their made website. Thanks.
~ Matt.
https://linustechtips.com/topic/658673-usb-rubber-ducky/
~ Matt.
Not gonna happen around these parts. Sorry.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/658673-usb-rubber-ducky/#findComment-8518056
Just now, mattonfire said:
What do you mean?
We do not support nor help with obtaining any type of tool that can be used for hacking, regardless of ones intent.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/658673-usb-rubber-ducky/#findComment-8518068
well.. two things:
1: from an engineering standpoint, that's probably a fair price.
2: as per community standards, we cannot recommend you to buy this product, we cannot explain you how to buy or use this product, nor can we agree to the concept of this product. this is not the place for hackers, with very VERY good reason.
https://linustechtips.com/topic/658673-usb-rubber-ducky/#findComment-8518072
Okay then, technically you don't know what I was going to use it for yet ;) but okay. I'll look somewhere else ^^
https://linustechtips.com/topic/658673-usb-rubber-ducky/#findComment-8518073
I dont think it matters if you want to use it to inject family pictures to your gma's pc.... it seems too hacker for ltt
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
https://linustechtips.com/topic/658673-usb-rubber-ducky/#findComment-8518118
