This is the only one (and it is better than the stock window) http://mnpctech.com/nzxt-h440-s340-razer-replacement-custom-window-smoked-clear-red-uv-green-blue/clear-replacement-cnc-machined-window-for-nzxt-h440-cases-clone.html
Or you can also contact NZXT and they will probably send you one for free cause they are nice.
https://linustechtips.com/topic/658497-s340-side-panel-window/#findComment-8515592
NZXT replaced every panel on my S340 for free cause shipping damaged them.
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
https://linustechtips.com/topic/658497-s340-side-panel-window/#findComment-8515705
Might be different because OP damaged it himself, but NZXT has great customer service and might give him a new window anyway.
He just needs to ask.
https://linustechtips.com/topic/658497-s340-side-panel-window/#findComment-8515713
Well they didn't seem to care that I admitted to the window cracking from me transporting my computer. Probably should've added that part in. :P
https://linustechtips.com/topic/658497-s340-side-panel-window/#findComment-8515722
