hello im in the process of gettting all my items together to build my gamming pc, pritty much a well off alright pc,..
ive managed to compose this list. i cant find a cheaper cooler with the same size radiator,
could use some help from you guys on cheaper items.
GTX 6GB 1060
http://pcpartpicker.com/list/ztWcHN
https://linustechtips.com/topic/657883-my-first-pc-build/
looks like a good build
CPUFX 8320, Motherboard ASUS M5A78L-M/USB3 Socket AM3+ AMD, RAM g.skill ripjaws x series (2x8gb), GPUstrix gtx 970, Storage 500gb + 500gb + 250 ssd, PSU EVGA 600w B 80 PLUS BRONZE, Display(s) ASUS VG248QE 24"+ Hisense 24" + Vizio 24", Cooling Cooler Master Hyper 212 EVO, PC Part Picker  http://pcpartpicker.com/p/LFxQ23
https://linustechtips.com/topic/657883-my-first-pc-build/#findComment-8507159
https://linustechtips.com/topic/657883-my-first-pc-build/#findComment-8507171
altho that card you have looks baller
https://linustechtips.com/topic/657883-my-first-pc-build/#findComment-8507176
Just now, dexxterlab97 said:
Good job keeping it black/white theme... wait is that a $140 mouse alone?
wow, did not even see how much it was, why not just the g502?
https://linustechtips.com/topic/657883-my-first-pc-build/#findComment-8507181
IMO I think you should see if you can get the price down <$1,500, I thought my build was amazing till I realized how much better I could have done for the same price.
Also, that mouse tho....
"I did it once... I can do it again! That's why I have two children" - Linus 2k15
https://linustechtips.com/topic/657883-my-first-pc-build/#findComment-8507192
Second this, G502 is a great mouse, you can even get the fancy RGB one for less than $140
https://linustechtips.com/topic/657883-my-first-pc-build/#findComment-8507204
His build is an entire computer system, not just the tower like most. he can't really lower the price on much of anything there except his peripherals and cpu cooler (which i don't think he should do anyway)
As for cheap mice, I use a G302 (you can get G303 if you want RGB) and its awesome. And it doesn't feel like a brick in your hand either. feels like a mouse should feel.
3 minutes ago, Jorgen297 said:
I have the same processor, and unless you're going for unsafe voltages, you can get a Cooler Master Hyper 612 V2. I get about 70C at 1.450v. Motherboard can be cheaper too unless you like the functionality of that one. All peripherals can be way cheaper,
Yeah.... but they're not going to be MUCH cheaper. and having cooling headroom is a good thing even if hes not going to go balls deep on his overclocks. More cooling headroom = quieter operation at the same performance levels.
https://linustechtips.com/topic/657883-my-first-pc-build/#findComment-8507238
Are you sure you want ASUS? I heard their customer support is terrible! I would consider ASRock, Gigabyte or MSI on the motherboard and on the GPU try to consider EVGA, MSI, Sapphire or XFX. (yes the last two is AMD only) :P
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
https://linustechtips.com/topic/657883-my-first-pc-build/#findComment-8507251
i chose something like this because my room is the hottest room in the house,
https://linustechtips.com/topic/657883-my-first-pc-build/#findComment-8507252
1 minute ago, Zyndo said:
His build is an entire computer system, not just the tower like most. he can't really lower the price on much of anything there except his peripherals.
Right but ... I'm just trying to express my own regret for my build; bought a Haswell processor right before Skylake came out, I didn't do my research well enough :P
Best he tries to save where he can, but overall its a pretty sick build.
How is the G302 vs the G502? (not relevant but curious)
https://linustechtips.com/topic/657883-my-first-pc-build/#findComment-8507263
then how does a mouse improve temperature. as far as I know that thing is not a cooler
lol srry, wrong reply, i thought i was quoting the cooler comment, in terms pf mouse i didnr see the 302 and its running cheaper right now.. i guess i chose the g900 for cable management
https://linustechtips.com/topic/657883-my-first-pc-build/#findComment-8507294
i chose this type of cooler since my room is the hottest room in the house..
https://linustechtips.com/topic/657883-my-first-pc-build/#findComment-8507305
Performance wise I believe its quite similar. the G502 would be technically better, but its "better" beyond the point of anyone, even pro gamers, being able to tell the difference. the advantage of the G502 is significantly higher DPI (up to 12k, compared to the 302's 4k... but the 303 has 12k as well). I don't know the lift off distance between the 302 and 502, but I use the 302 and its pretty good. I guess the other advantage of the 502 would be its customization options and added mouse buttons... But i consider that a whole bunch of unecessary fluff. I've been using the 302 for many years now. The only upgrade I want to make is to a G303 so i can RGB it haha. love this mouse.
https://linustechtips.com/topic/657883-my-first-pc-build/#findComment-8507805
... Well, yeah but... can your mouse do this?! https://www.youtube.com/watch?v=FmfTzpfwEEc
But in all seriousness revamping my build currently, will likely look into the 302/303 and use the 502 as a portable mouse
https://linustechtips.com/topic/657883-my-first-pc-build/#findComment-8507828
lolololol. thats great.
Don't get me wrong, the 502 is objectively better. it has more buttons, more features, more customization. But all of that comes at a price, and I really like the feel and shape of simple mice. I don't need all that extra fluff (and actually don't want it). The actual responsiveness and handling should be quite similar (dpi aside) is all I was saying. That being said I've never actually used the G502, so this is all based on paper stats. in reality they could very well be day and night different to the right person.
https://linustechtips.com/topic/657883-my-first-pc-build/#findComment-8507858
