help me guys, i just built my own pc, it's running on windows 10, but when i play games (dota 2, csgo, etc) , my computer dies (bsod) and it says "thread_stuck_in_device_driver" help me guysss!
my computer specs:
Processor: AMD A10 7860k
GPU: A10 graphics
Mobo: Gigabyte G1 Sniper A88X
Ram: Kingston HyperX Fury 8gb 1866mhz
HDD: Western 1TB Sata Green
PSU: huntkey 600w
OS: Windows 10
https://linustechtips.com/topic/657844-help-me/
Cause
A device driver is spinning in an infinite loop, most likely waiting for hardware to become idle.
This usually indicates problem with the hardware itself, or with the device driver programming the hardware incorrectly. Frequently, this is the result of a bad video card or a bad display driver.
From https://msdn.microsoft.com/en-us/library/windows/hardware/ff560350(v=vs.85).aspx
Yes, I know i just ripped it off but googling can be helpful
https://linustechtips.com/topic/657844-help-me/#findComment-8506673
my computer specs:
GPU: A10 graphics
Are you using the latest APU driver?
https://linustechtips.com/topic/657844-help-me/#findComment-8506682
8 minutes ago, Eragon said:
Cause
but i just run integrated graphics from my apu
https://linustechtips.com/topic/657844-help-me/#findComment-8506745
1 minute ago, Arkkkkkkkkkkkkkkkkkkkkkkkk said:
accelerated processing unit - means my cpu is both CPU and GPU
Most of the AMD driver issues are fixable with a fresh install of windows as sometimes the actual driver may have corrupted files within the windows display driver system. That happened to me and a fresh install of windows cleaned out my PC and after that, my PC now runs smoothly without a hitch. (only do this as a last resort though)
I suck a typing, preparw for typos.
Desktop
CPU: Ryzen 7 3700x MOBO: MSI X570-A Pro RAM: 32 GB Corsair DDR4
GPUS: Gigabyte GTX 1660ti OC 6G  CASE: Corsair Carbide 100R STORAGE: Samsung Evo 960 500GB, Crucial P1 M.2 NVME 1TB   PSU: Corsair CX550M CPU COOLER: Corsair H100x
LAPTOP
Apple Macbook Pro 13 M1 Pro
https://linustechtips.com/topic/657844-help-me/#findComment-8506789
yes i reinstalled windows 10 a lot of time already, but i think it's the crimson driver's fault.
https://linustechtips.com/topic/657844-help-me/#findComment-8506823
10 minutes ago, Arkkkkkkkkkkkkkkkkkkkkkkkk said:
i reinstalled it like 10 times and it's still like this
Have you tried an older driver? You can install a driver from a couple revisions back, the worst that happens is you lose out on a few optimizations.
Best case is it stops your crashes for now and maybe the next driver release will be more stable.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/657844-help-me/#findComment-8506831
Try a SCF scannow command in cmd to diagnose errors.
Desktop
LAPTOP
https://linustechtips.com/topic/657844-help-me/#findComment-8506835
yes i tried an older driver, like the catalyst, but i'm on windows 10, it just reinstalls the latest. how can i stop windows from automatic updating the display driver?
https://linustechtips.com/topic/657844-help-me/#findComment-8506854
how can i do that?
Open Command prompt as administrator and then type in "sfc /scannow" without the quotation marks. Then press enter, from that point it will take time checking windows for corruptions.
Desktop
LAPTOP
https://linustechtips.com/topic/657844-help-me/#findComment-8506856
done what will i do next?
https://linustechtips.com/topic/657844-help-me/#findComment-8507029
Wait for it to finish checking and if it says errors were found and fixed then restart your PC if not then it may be a driver bug or even hardware issue.
Desktop
LAPTOP
https://linustechtips.com/topic/657844-help-me/#findComment-8507061
