It looks like this cooler.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118139
I used it briefly. If it's the same one, there's a lever that runs across and through it.  It pivots on one side only, so the release is on the opposite.
If it's not the same one, look under the board. The release(s) might be there.
https://linustechtips.com/topic/657619-annoying-cpu-cooler/#findComment-8503919
If it's not held in place by a clip, there's a good chance it's held in from the back.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
https://linustechtips.com/topic/657619-annoying-cpu-cooler/#findComment-8503926
4 minutes ago, DaMonstah said:
i see a screw but can't get to it because of the fan, it may also be stuck :S
There should be a clip in one of the bit without the heat spreader, that you can press down on to get it off. Other wise there will be a screw there. You might have to go in at an angle between the fan blades.
I am a paid professional, but only when I am at work...and getting paid.
https://linustechtips.com/topic/657619-annoying-cpu-cooler/#findComment-8503976
Can you post a picture of the screw?
https://linustechtips.com/topic/657619-annoying-cpu-cooler/#findComment-8504004
