Posted September 9, 2016 Author @WoodenMarker I have much left.. i have 352W on PCPartPicker.. more than enough haha with a better graphics card btw Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 10, 2016 Author btw @WoodenMarkerhttp://www.sapphiretech.com/productdetial.asp?pid=C4D1B443-6105-4A63-85DE-1732CC9C443D&lang=eng this is my GPU atm.. it recommends 500W PSU.. You sure im al good? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 10, 2016 Just now, Huibert said: btw @WoodenMarkerhttp://www.sapphiretech.com/productdetial.asp?pid=C4D1B443-6105-4A63-85DE-1732CC9C443D&lang=eng this is my GPU atm.. it recommends 500W PSU.. You sure im al good? Yes, you're fine. If you ever need help with a build, read the following before posting: http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/Also, make sure to quote a post or tag a member when replying or else they won't get a notification that you replied to them. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 10, 2016 Author @WoodenMarker Oke! its solved now ty.. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 14, 2016 Author @WoodenMarker I completely changed my mind and it turns out to be this http://pcpartpicker.com/list/rK6dHN is my PSU still good enough to handle this and what do you think of this build..? Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted September 14, 2016 57 minutes ago, Huibert said: @WoodenMarker I completely changed my mind and it turns out to be this http://pcpartpicker.com/list/rK6dHN is my PSU still good enough to handle this and what do you think of this build..? Yes, it's fine. You can generally estimate the psu size you should get by the graphics card alone because it usually takes the most power. If you ever need help with a build, read the following before posting: http://linustechtips.com/main/topic/3061-build-plan-thread-recommendations-please-read-before-posting/Also, make sure to quote a post or tag a member when replying or else they won't get a notification that you replied to them. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
