https://gyazo.com/e50405ddadf72cb6c9168041e9a65d8a
Hi everyone,
I was planning on building a PC i have one already but i dont know if i need to upgrade my Power Supply.
The one that is in my PC is a https://pcpartpicker.com/product/PHCwrH/corsair-power-supply-cx500m
(Corsair CX 500W 80= Bronze)
Should i Upgrade?
ps. im planning on overclocking and i dont know if i should pick Liquad cooling or Air cooling..
(Corsair Hydro H100i V2 or the be quiet! Dark Rock Pro 3) or something else if it is gonna be better..
https://linustechtips.com/topic/657536-power-supply-voltage/
Hi everyone,
Should i Upgrade?
psu is SHIT.
at 100$ air cooling and 240m liquid coolers perform around the same
Build
Ryzen 5 1600, Cooler Master Hyper 212 Evo, Gigabyte X470 Gaming 7. TeamGroup Viper 4133mhz 16gb, XFX RX 480 8 GB (1000mhz cause dying), Samsung 850 EVO 250 GB M.2 SSD, An old 1tb 5400 rpm 2.5" HDD, TeamGroup 480gb & Kingston 480gb ssds (May RAID 0), 1TB Western Ditigal HDD, EVGA 750W G2 PSU, Phanteks P400s
----------X-----------X------------
https://linustechtips.com/topic/657536-power-supply-voltage/#findComment-8502891
Hi everyone,
Should i Upgrade?
http://www.tomshardware.com/forum/id-2547993/psu-tier-list.html
use this
Build
https://linustechtips.com/topic/657536-power-supply-voltage/#findComment-8502900
Just now, Huibert said:
@DeezNoNos
I have not the biggest Budget so i dont want to spend too much on my power supply..
Really appreciate the help ;)
there are budget psus from tier 2.
Like the seasonic M1211
or the xfx t2.
less than $70 and never cheap out on ur keyboard
Build
https://linustechtips.com/topic/657536-power-supply-voltage/#findComment-8502942
2 hours ago, Huibert said:
@DeezNoNos
Why do i need a Modulair power supply?
it doesnt seem to have a very big difference right..?
Easier to manage cables that way. Anyways, a Seasonic S12 would be better than the CX500M. A CX450M would be better than the CX500M as well.
https://linustechtips.com/topic/657536-power-supply-voltage/#findComment-8503777
No graphics card?
https://linustechtips.com/topic/657536-power-supply-voltage/#findComment-8503814
@WoodenMarker
I have already one im upgrading that later!
What graphics card do you have and what are you planning to upgrade to?
https://linustechtips.com/topic/657536-power-supply-voltage/#findComment-8503861
1 minute ago, Huibert said:
@WoodenMarker
Now i have the Sapphire Dual-X R9 280 3G D5 and i dont know when im gonna upgrade or what..
Maybe GTX 1060 or something idk
The 1060 draws even less power than the 280. There's no need to upgrade your psu.
https://linustechtips.com/topic/657536-power-supply-voltage/#findComment-8503888
@WoodenMarker
Yeah but the GPU upgrade is gonna be i think next year so a bunch of new GPU's are gonna come out..
This is the current status of the build: https://gyazo.com/15f91622f7fa1c4f35458cff08945872
and i got a bunch of different PSU's:
http://pcpartpicker.com/product/6p8H99/evga-power-supply-220p20650x1
http://pcpartpicker.com/product/h3FXsY/evga-power-supply-220gs0650v1
http://pcpartpicker.com/product/9q4NnQ/evga-power-supply-220g20650y1
Wich one do you prefer?
https://linustechtips.com/topic/657536-power-supply-voltage/#findComment-8503947
https://linustechtips.com/topic/657536-power-supply-voltage/#findComment-8503954
@WoodenMarker
Nah.. lol..
I mean that saw them on the internet and someone helped me with choosing these PSU's but i wanna get the best one for the budget..
so i asked wich one of these do you prefer :P
Your current psu is fine--why replace it?
https://linustechtips.com/topic/657536-power-supply-voltage/#findComment-8503973
@WoodenMarker
My cx500m?
people telling me i should upgrade it for the new build so its gonna be good when upgrading etc..
Yes, your cx500m is fine. There's no need to upgrade.
https://linustechtips.com/topic/657536-power-supply-voltage/#findComment-8503992
1 hour ago, Huibert said:
@WoodenMarker
Btw how do you know it is enough? i believe you but i like too know!
55 minutes ago, Huibert said:
@WoodenMarker
and with a OC is it still enough or doesn't anything have to do with the wattage while overclocking..
Your current psu is enough because your system doesn't draw that much power.
Here's an example of power draw at load from the wall with an oc'ed 3960x and an r9 280: http://www.tweaktown.com/reviews/6573/gigabyte-radeon-r9-280-windforce-3gb-oc-video-card-review/index16.html
Keep in mind that the numbers shown are from the wall and are higher than how much power the components draw because of psu inefficiency and that it's more power hungry than a system with a 6700k.
Oc'ing can mean higher power draw but the cx500m has plenty of headroom for oc'ing.
https://linustechtips.com/topic/657536-power-supply-voltage/#findComment-8504539
@WoodenMarker
Alright i see now! Thank you man.. btw is the wattage from pcpartpicker right?
and you saved me alot of money.. :)
The wattage pcpartpicker displays is usually not too far from the mark.
https://linustechtips.com/topic/657536-power-supply-voltage/#findComment-8504572
